Bolwell Aribba XS Speedo not working
Last post 07-02-2009 05:11 AM by Petew1983. 3 replies.
  • 06-29-2009 02:24 PM
    Hi guys, Just wondering if anyone might be able to help. My Bolwell Arriba XS (2003) has a problem, the speedo stopped working today. Is there any simple diagnosis or what would I need to do to fix it? I have checked the speedo cable and it appears in tact.
     Any help that you could provide would be appreciated.
  • 06-29-2009 03:28 PM In reply to
    Re: Bolwell Aribba XS Speedo not working
    Nine times out of ten, it's the cable, even though it might look intact. Your local Select (PGO) dealer will be able to supply one for somewhere around $40 (give or take a bit). If it's not the cable, it could be the speedo drive that it mounted on the front wheel.
    Put the scoot up on the main stand, remove the cable from the drive on the front wheel, and have a look in the cable hole on the drive unit as you spin the front wheel by hand. The little flat tab inside turns slower than the wheel, but if it is turning, then that one is eliminated. Re-attach the speedo cable.
    Next, pull the dash apart so you can get your fingers on the knurled upper end nut of the cable, and undo it. You'll see a piece of inner cable sticking out. Again, spin the front wheel, and see if that piece of inner cable is turning. If not, then the cable has had the biscuit. If it is all turning properly, then it could be the dash, although that is less likely than the cable or drive unit...
    Good luck with it.
  • 07-02-2009 05:09 AM In reply to
    Thanks for that mate. I did exactly what you said. The sensor on the wheel appears to be ticking over ok and when I take the top off to look at the cable spinning it appears to be doing this fine as well.
     Could it be the actual "console" as such? Maybe the cable is slipping inside the speedo reader on the dash. (sorry I am not up to date with technical terms) If this is the problem where would I source parts for this?
  • 07-02-2009 05:11 AM In reply to
    Oh, sorry. Is there anything else I should be looking for?
