Oil, what is best for bolwell le grande?
Last post 09-19-2009 07:14 PM by INMA. 6 replies.
Page 1 of 1 (7 items)
  • 09-14-2009 04:38 PM
     Hi
    Can anyone tell me what oil I should use for the first oil change and etc (eg brand, synthetic ) for a bolwell le grande scooter.
    Regards scootcrazy
  • 09-14-2009 05:53 PM In reply to
    Re: Oil, what is best for bolwell le grande?
     Personally i don't switch to synthetic oil until about 5000ks to give time for all the mechanical bits to bed in correctly . So i would use a mineral oil for the first change 10w40 motorcycle oil from any well known brand will do the job
  • 09-14-2009 05:58 PM In reply to
    • niks
    • Joined on 01-22-2009
    • Melbourne
    • Posts 1,114
    I second pyrah's thoughts on this.
  • 09-17-2009 10:56 AM In reply to
     Hi everyone, sorry for the late reply, my hubby is grateful for the advice and we are going to go to total motorcycle accessories tomorrow to have a look for the oil.
  • 09-18-2009 10:35 PM In reply to
    Hi,  We went to total motorcycle accessories, and several other shops,  also a motorbike, scooter shop today.  We couldn't find mineral oil       (10W 40).  The advice we were given was that (15W 40) shell Fortified synthetic oil was okay for the first oil change. Just wondering if anyone can give some advice on this.
    Regards Scoot Crazy
  • 09-19-2009 10:01 AM In reply to
     That should be OK then go to  a fully synthetic oil ones the engine is fully run in
  • 09-19-2009 07:14 PM In reply to
    I can't think of any 4 stroke scooter that would benifit from using synthetic oils.
    Scooter engines have such low stresses and low temperatures that there is no reason to use synthetic oils and no advantage.
    Good quality mineral based oils would provide equivalent protection and no change in wear rates without the expense of the synthetic oil.
    Synthetic oils have some value when piston speeds and camshaft speeds go up or where exhaust temperatures get above about 600 degrees celsius.  Unless you have an engine reving well over 10,000RPM or a higher state of tune for racing the standard oils are fine.
