Gtr track car
Last post 11-25-2009 02:09 PM by R1hoon. 9 replies.
Page 1 of 1 (10 items)
  • 11-24-2009 06:57 PM
    • waxhead
    • Joined on 12-17-2007
    • gold coast
    • Posts 882
    Gtr track car
    I thought you guys may be interested in a gtr track car engine i am building for some one
    This is the nissan godzilla skyline
    Just been working on the head today and have the intakes close to finished
    Will just hit them with the sandblaster after this to get a uniform  finish on all the ports i dont want them in a polished state
  • 11-24-2009 08:24 PM In reply to
    Re: Gtr track car
    waxhead:
    Why? I thought polishing ports was the go..?
  • 11-24-2009 08:57 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Re: Gtr track car
    No it makes the fuel drop out of suspension and you lose power
    I polish them up as you can see then rough them up again but when I rough these ports up its uniform
    If you look into any of my two stroke engines you will see the same rough finish
    This is a picture of my old porting style on  mineralli scooter cases
  • 11-25-2009 12:37 AM In reply to
    • 15UZU
    • Joined on 01-08-2009
    • Slacks Creek, QLD
    • Posts 1,140
    Re: Gtr track car
    waxhead:
    Correct, but this really more of an issue with carby applications (especially low RPM applications) than with EFI setups where the injector is positioned to spray towards the back of the open valve and the fuel spends much less time in the airstream.
    I've heard debates people have argued that the atomised droplets are more likely to stick & condense on a roughened surface compared to a polished one behind the valve (talking EFI application only). The theory is that the roughened surface will provide more of an opportunity (greater surface area & possible capillary grip) for the atomised droplets to hit & stick compared to a polished surface with finer texture which would permit the super fine droplets to bounce or slide quickly into the chamber & not stay on the wall long enough to puddle.
    I honestly don't think on a hipo street car it really makes that much of a difference that it's worth arguing about - would be different if you're talking F1 though I suppose.
    2010 PGO X-Hot 150cc - clocking up the kays
    2006 Vmoto Monza 50cc - to be rebuilt......I wonder if I can get this TMAX 500 engine in here??? o_O
    2005 Vmoto Monza 50cc - in the rebuild phase
    2002 Aprilia SR50 50cc - currently out on loan
  • 11-25-2009 07:20 AM In reply to
    • Posts 841
    Re: Gtr track car
    The port finish does make a huge difference.
    I had not been aware of sand blasting being suitable, we always used as cast on the atmospheric engines.  Superchargers might be a bit different.
    I can't see a lot of work around the inlet valve seats, I suppose just increasing the bost flows wharever you want, too easy.
    I am going back 30 years so things might have changed.
  • 11-25-2009 07:42 AM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Re: Gtr track car
    INMA:
    Yeah I have always found that the rough port makes better hp everywhere
    I would be interested in reading an article that states otherwise
    I alwasy dedag head do my porting and then sand blast with garnett , leaves a beautiful mild corse finish
    I had the throats bored on the inlet side and have them blended them in to the port
    Its hard to see in these pics are you are seeing the after pics and the step has gone
    In realty these are one of the best inlet ports i have seen in a long time and didnt need alot of work to get there flow right up there
  • 11-25-2009 09:21 AM In reply to
    Re: Gtr track car
    I guess the slightly coarse surface would create microscopic eddy currents that would help to keep the fuel suspended. In the same way the dimples on a golf ball create eddy currents that bring stability to it's flight. But then, if the surface is too coarse- like a really rough casting, then the turbulence would be much greater, and would have the opposite effect...
    just thinking out loud.
  • 11-25-2009 10:21 AM In reply to
    • Posts 841
    Re: Gtr track car
    Wax, do you use a flow bench?
    I did not see any signs of significant work in the combustion chamber.  On the Datsun L engines there was a need to relieve the area to the side of the inlets to improve flow when the valves were partially open.
  • 11-25-2009 12:17 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Re: Gtr track car
     Yeah i have a flow bench i can use and i do some times but i more interested in the same flow between cylinders than trying to drag big numbers out of it
    Some times people spend so much time getting flow and loose power due to slow moving air
    The head is not finished yet
    Im just working the intakes and will go on to the exhaust soon actually as i write this i have the exhaust close to finished.
    In the combustion chamber i will be cutting back the quench area as its a known point for deto on these engines
  • 11-25-2009 02:09 PM In reply to
    • R1hoon
    • Joined on 10-02-2007
    • Brisbane
    • Posts 439
    Re: Gtr track car
    the scooter shop:
    CORRECT - and infact flows faster, that's laminar flow and boundary layer.
    I was going to write a witty and clever comment here, then thought "naa screw it" -- I'm just gunna be a smart a$$.
