Vmoto Carby
Last post 01-29-2010 05:36 PM by ne32. 5 replies.
Page 1 of 1 (6 items)
  • 01-20-2010 07:38 PM
    • ne32
    • Joined on 12-30-2009
    • Posts 8
    Vmoto Carby
    Can anyone tell me the brand or model/style carby that is standard on my Vmoto Milan. I have fitted a Pipe , Variator , Springs and Kevlar belt and apparently I should be using a bigger jet. What jet size is standard ?
    Thanks
  • 01-22-2010 12:16 PM In reply to
    Re: Vmoto Carby
    its a 17mm Mikuni copy runs a 70 main jet which is quite big for a stock 50. You don't necesarily have to run a bigger jet. If you are running something like a Gianelli "Go" you'll probably only need to adjust needle height.
  • 01-22-2010 12:20 PM In reply to
    Re: Vmoto Carby
    ne32, what pipe are you running on the Milan?
    HAs it made much difference to how the scooter goes?
  • 01-22-2010 05:05 PM In reply to
    • ne32
    • Posts 8
    Re: Vmoto Carby
    Thanks for that help with the carby Brendon
    Leovince ZX Pipe - It fits the bike well . Is it legal ? Probably not. I tried it first with the stock clutch springs and variator and with that combo it was worse then stock pipe on hills unless you hit them with a fair bit of speed. On the flat it was noticably quicker from about 20km/h and up.
    The pipe included a set of variator weights and clutch springs and that helped increase the revs a bit before loading up the motor but I am yet to finish putting in the aftermarket Polini Variator  .
  • 01-22-2010 05:14 PM In reply to
    Re: Vmoto Carby
    ne32:
    Is it legal ?
    hehehe
    Don't forget the rear contra spring, transmission needs to engage at higer revs. Just check the pipe isn't going to hit the rear quarter panel when the suspension compresses
  • 01-29-2010 05:36 PM In reply to
    • ne32
    • Posts 8
    Re: Vmoto Carby
    I have the Contra spring
    Done about 30km with the pipe and it didn't once bump the body like I thought it might.
    Anyone know if the Horizontal and Vertical Minarelli crank are the same or not?
