Can someone explain why this test question was wrong?
Last post 07-04-2010 04:48 PM by TRA. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • 03-12-2010 10:57 AM In reply to
    • WaspLover
    • Joined on 09-04-2009
    • Mainland, Shaky Isles
    • Posts 163
    Re: Can someone explain why this test question was wrong?
    Like others have said, uncontrolled junction, give way to right (no matter what). However if "Y" is at the top, turning into the same road as "X" at the bottom, then "Y" will have the right of way in Australia, but "X" will have the right of way in NZ Cool
    Recently I came up onto a junction similar to this and is bi-directional but is controlled by traffic lights. Unfortunately the traffic lights broke down and it was peak hour traffic, so all the lanes are packed full with vehicles trying to cross and give way to each other. I survived!
    Mocker Club Member
  • 05-16-2010 06:13 PM In reply to
    • 15UZU
    • Joined on 01-08-2009
    • Slacks Creek, QLD
    • Posts 1,140
    The "give way to right" not only applies to intersenctions......when merging onto motorways & when two lanes merge into one without the dividing line indicating which lane ends the give way to right also applies. Wink
    Interestingly "Colregs" (Colisions Regulations) for boating also adhere to the "Give way to right" as well......i.e. a boat approaching on your starboard side has right of way over you (that is unless it is a larger less manouverable vessel than yours).
    2010 PGO X-Hot 150cc - clocking up the kays
    2006 Vmoto Monza 50cc - to be rebuilt......I wonder if I can get this TMAX 500 engine in here??? o_O
    2005 Vmoto Monza 50cc - in the rebuild phase
    2002 Aprilia SR50 50cc - currently out on loan
  • 05-16-2010 06:42 PM In reply to
     Does steam still have to give way to sail
  • 05-16-2010 07:00 PM In reply to
    • 15UZU
    • Slacks Creek, QLD
    • Posts 1,140
    Wasn't aware of that one (I'll have to go look it up Embarrassed), but basically the less manouverable vessel in the situation has right of way
  • 05-16-2010 09:48 PM In reply to
    • miketl
    • Joined on 10-08-2007
    • Kingston, Southern Tassie
    • Posts 755
    Rule 3b of the col regs states "power-driven vessel" means any vessel propelled by machinery.
    Rule 18a of the col regs states that a power-driven vessel underway shall keep out of the way of a sailing vessel
    so, yes pyrah, in general steam has to give way to sail.  The main exception to this is where a sail boat is overtaking ...
    Rule 13a of the col regs states that any vessel overtaking any other shall keep out of the way of the vessel being overtaken
    ciao,  Mike
    Riding an 08 Vespa PX 200, and a 2012 Harley Sportster 883 Superlow
    previously big red Audrey an Aprilia Scarabeo 500ie, an Aprilia Scarabeo 200, and originally a Suzuki F50 Step-through
  • 05-16-2010 10:11 PM In reply to
    • 15UZU
    • Slacks Creek, QLD
    • Posts 1,140
    Thanks Mike.......I know there is an execption in there somewhere though for commecial shipping.........
  • 05-17-2010 12:30 AM In reply to
    Big Smile I'm glad i was on Submarines missed a lot of the shipping problems Wink
  • 07-04-2010 08:37 AM In reply to
    So is there a 'give way to those above you' rule or a'give way to those below you' rule or is it simply a 'give way to the one with the biggest torpedoes'. May be we should have that at intersections. I know I have felt a flame thrower attached to the front of my scoot would be a valuable and usefull addition!
    Previously many road/trail bikes
    Honda Spacy , Scarabeo 200
    Hyundai Rally 100, Scarabeo 500
    MP3 250, Hyosung gv650
    Fuoco, Bonniville
    Piaggio Fly 125
    Scarabeo 500ie (2010)
    Piaggio Fly 150ie (2012)+
    Suzuki Boulevard M50
    http://www.coffeescoffer.com
    http://tastag.coffeescoffer.com (forum)
  • 07-04-2010 09:39 AM In reply to
    Big Smile  With 16 nuclear missiles most things gave way to us Stick out tongue
  • 07-04-2010 03:27 PM In reply to
    • 15UZU
    • Slacks Creek, QLD
    • Posts 1,140
    Except for the seabed Stick out tongue
  • 07-04-2010 04:48 PM In reply to
    • TRA
    • Joined on 05-09-2010
    • Posts 302
    miketl:
    ciao,  Mike
    Actually, if you interpret the colregs a little more you will discover that the less manouverable boat has right of way!
    The original question, the answer in QLD is covered by s72 of the Transport Operations (Road Use Management—Road Rules) Regulation which is based on the Australia Road Rules s72. Given most states base their road rules and the Australian Road Rules you will also likely find it under s72 in other states!
    Australia Road Rules s72 (3)
    If the driver is going straight ahead, the driver must give
    way to any vehicle approaching from the right, unless a stop
    sign, stop line, give way sign or give way line applies to the
    driver of the approaching vehicle.
