Replacing a Headlight Bulb in a Vespa GTS
Last post 05-10-2010 09:57 PM by petegailey. 13 replies.
Page 1 of 1 (14 items)
  • 05-10-2010 09:19 PM
    • Posts 7,087
    I realised the other night that my low beam had stopped working and that I had to replace the headlight bulb. I bought a new 12V 60/55W H4 Narva plus 50 halogen bulb from Repco for $22 got hold of the Vespa manual and proceeded to try and get to the headlight.
    The first step is to get the brake reservoir cover off. You need a special star type screwdriver bit to get these screws out.
  • 05-10-2010 09:26 PM In reply to
    • Posts 7,087
    Re: Replacing a Headlight Bulb in a Vespa GTS
    Once the cover was off I could get to the mirrors
  • 05-10-2010 09:29 PM In reply to
    • Posts 7,087
    With a 17mm spanner I was able to unbolt the mirrors. It was a bit tricky working out whether I was tightening or loosening the bolts.
  • 05-10-2010 09:31 PM In reply to
    • Posts 7,087
    With both mirrors off the next thing is to remove the horn cover. to get to this you have to remove the plastic Piaggio badge at the front of the GTS. I managed to get it off with my finger nail.
  • 05-10-2010 09:33 PM In reply to
    • Posts 7,087
    With the badge removed you can get to the screw that holds the horn cover on. All the screws from now on are phillips head.
  • 05-10-2010 09:36 PM In reply to
    • Posts 7,087
    With the horn cover removed you can get to the front headlight cover screw under the headlight.
    BE CAREFUL NOT TO DROP THIS SCREW!
  • 05-10-2010 09:38 PM In reply to
    • Posts 7,087
    Next you remove the two fixing screws at the rear of the handle bars.
  • 05-10-2010 09:40 PM In reply to
    • Posts 7,087
    The other side
  • 05-10-2010 09:44 PM In reply to
    • Posts 7,087
    And after much wiggling and twisting and gently prising and cursing the headlight assembly suddenly comes free.
  • 05-10-2010 09:49 PM In reply to
    • Posts 7,087
    You can now disconnect the wiring and remove the headlight assembly.
  • 05-10-2010 09:52 PM In reply to
    • Posts 7,087
    This is the GTS with the headlight assembly removed
  • 05-10-2010 09:54 PM In reply to
    • Posts 7,087
    This gives you access to the headlight bulb. You pull the rubber away to get access to the back of the light bulb sitting in a ceramic plate.
  • 05-10-2010 09:56 PM In reply to
    • Posts 7,087
    You twist the ceramic back plate of the bulb and it comes away.
  • 05-10-2010 09:57 PM In reply to
    • Posts 7,087
    You can now replace the bulb. When putting in the new bulb you have to be careful not to put your fingers on the glass bit coz this can bugger the bulb. Putting it all back together again is just the same only in the opposite order. The Plus 50 bulb is supposed to be 50% brighter that a conventional halogen bulb and yes it is a vast improvement but boy its quite a complicated process just to change a light bulb.
