Advice About oil
Last post 03-05-2011 06:59 PM by pyrah. 6 replies.
Page 1 of 1 (7 items)
  • 03-04-2011 01:45 PM
    • goulam
    • Joined on 02-15-2011
    • Posts 6
    Advice About oil
    hi guys
    can you fill the oil occasionally or you have to wait till the light to come on?
  • 03-04-2011 01:55 PM In reply to
    Re: Advice About oil
    goulam:
    hi guys
     You should be filling before your light comes on.  With a 2 stroke, get into the habit of topping up every fortnight, when you do your normal checks like tyre pressue etc.
    Just a question.  When you bought your scooter, did your dealer go thru these things with you.  They should have advised what oil to use, how to check the oil, and when to check the oil etc.
  • 03-04-2011 02:00 PM In reply to
     I check my oil weekly as well as tyre pressure etc and top up as required
  • 03-04-2011 02:52 PM In reply to
    • goulam
    • Posts 6
    i have a 2 stroke aprilia sportcity one, they said to check it monthly.
    so does that mean i have to refill when am checking it the oil?
  • 03-04-2011 03:04 PM In reply to
    goulam:
     Most 2 strokes i have had i normally topped up the oil tank on every 4th fill up of the petrol tank plus i would check the oil level weekly when doing  my other checks .
  • 03-05-2011 06:46 PM In reply to
    • goulam
    • Posts 6
    thank pyra......what are the any other checks that you do apart from the oil, brake   & tyre checks
  • 03-05-2011 06:59 PM In reply to
    Also check that light & indicators are working . Brake fluid level is OK & a general look round the scooter to see if anything is working loose
