Fuoco is dying
Last post 06-01-2011 07:18 PM by steve@ace. 12 replies.
  • 04-03-2011 09:34 PM
    Fuoco is dying
    Hi all,
    Lately my Fuoco has developed this nasty habit of just dying on me for no apparent reason, sometimes it just splutters and then picks up again and keeps going. Other times it dies as suddenly as if the kill switch had been hit, when it dies, after I stop I then start it normally and off we go again.
    My major concern is that when it dies anyone following close behind me is likely to run over the top of me and sometimes I have no escape route so have to endure the fist shaking and finger gesticulating from irate drivers.
    At first I thought maybe water in the fuel, I added some metho to the the fuel hoping to mop up any water but to no avail. Then I thought maybe spark plugs and discovered that NGK CR4EBK plugs don't exist in the real world and so bought some CR7EIX and tried those, there was a marginal improvement in smoothness but not in the cutting out problem.
    The Gilera dealer in Batemans Bay couldn't find a problem as the puter had no fault codes registered in it. Anyone have any ideas at what I maybe can or should look at next? Any and all suggestions will be entertained
    You're as bad as me, you used to be so much better, that makes you worse.
    Red Gilera Fuoco 500ie
  • 04-03-2011 11:33 PM In reply to
    Re: Fuoco is dying
     You could try new copper plug lead & cap also is the fuel filter & line OK or maybe faulty fuel pump like on some Vespas
    Si ‘Thi’ later
  • 04-04-2011 07:08 AM In reply to
    • Posts 7,090
    Re: Fuoco is dying
    It does sound like it could be the fuel pump.
  • 04-04-2011 08:15 AM In reply to
    Re: Fuoco is dying
    Loose Change:
    Do you lose all the instrumentation when it cuts out?
    Slow Down & Enjoy The Ride
    2012 Kawasaki W800
    Go the Retro
    Looking for another BeeWee :)
  • 04-04-2011 09:35 AM In reply to
    Re: Fuoco is dying
    "Do you lose all the instrumentation when it cuts out?"
    No, all instruments function as normal and power to the bike is not compromised either, that is everything works as it should except the plugs won't sparkle.
  • 04-04-2011 01:58 PM In reply to
    Re: Fuoco is dying
     Could be intermittent fault on the ignition system coil the trigger or ignition module Sad
    Si ‘Thi’ later
  • 04-04-2011 04:40 PM In reply to
    Re: Fuoco is dying
    If I had a fuel problem in my Guzzi the ie light on the dash would come on, I assume you would have a similar warning on the Fuocco. Does this usually occur under load?
    2012 Kawasaki W800
    Go the Retro
  • 04-04-2011 04:53 PM In reply to
    Re: Fuoco is dying
    was it when it was just above idle speed and pick up a handful of revs?
    or maybe the fuel cap air inlet is blocked.
  • 04-04-2011 04:57 PM In reply to
    Re: Fuoco is dying
    I would go with Pete's theory that the fuel pump should be checked out. Is it when the scooter is hot, been running for a while ?
  • 04-04-2011 09:09 PM In reply to
    Re: Fuoco is dying
    Thanks for all the thoughts and suggestions, I will check the ignition module thingy and also the fuel cap breather.
    As to when it happens, yes so far it has always been when the engine has been at normal operating temps and has happened both at highway speeds and also at lower speeds, sometimes it has even coughed and spluttered at startup, but never when cold.
    It's just very frustrating when it dies on you on the highway just as you are about to be run over by a B double because you can't outrun it and he hasn't a clue what's going on.
  • 04-24-2011 09:44 PM In reply to
    Re: Fuoco is dying
    Thanks to all the replies I had regarding the problem and it seems to now be running as it was intended to. It appears the problem was a very touchy kill switch, I was doing something on the bike and my hand just barely touched the kill switch and the engine stumbled and nearly died. I then cycled the kill switch about a dozen times to clean the maybe dirty contacts, anyhow to cut a long story ....... the bike for now runs great.
  • 04-24-2011 11:44 PM In reply to
    Re: Fuoco is dying
     Thats good  thanks for the feed back will commit that one to memory Yes
    Si ‘Thi’ later
  • 06-01-2011 07:18 PM In reply to
    Re: Fuoco is dying
    We had a similar one only a couple weeks ago with an X8 250.  Ended up just disconnecting the switch since it was never used anyway.
