Piaggio Fly 150 (4T Euro 3) Bulb Specs
Last post 04-16-2011 10:44 PM by chritker. 0 replies.
Page 1 of 1 (1 items)
  • 04-16-2011 10:44 PM
    Hi All,
    I've been doing some research on what bayonet and bulb types fit the Piaggio Fly 150 (4T Euro 3).
    Brake/Rear Running Light
    - BAW15d 1157
    Blinkers
    - BAU15s 1156
    - If you're going to upgrade to LEDs you may need load resistors to reduce the fast flash rate.
    The difference between BAU15s and BA15s
    Dashboard Lights
    - I'm not sure what these are called? But you can buy or make your own:
    Video of: Dash LED Upgrade
    The closest I've come to identifying what the dashboard housing is -
    http://www.m-99.co.uk/Car_Neon_LED_Lighting/Dashboard_LED_Bulbs/dashboard_led_bulbs.html
    Below is the packet of the LEDs that best fit the dash socket. I bought them from the website above, when purchasing you'll have to specifiy the exact model as there are differing types of dash LED/globes even though they are 509T.
    Video of: green blinker LED (left) v stock bulb (right)
    Video of: green blinker LEDs both sides
    Headlight
    - 12728 S2 Philips Duplo 12V 35/35W (BA20d socket)
    If you search on eBay there is a wide range of BA20d globes available. I purchased the globe below and it is a lot brighter than stock with a nice white light. The BA20d socket on this globe is slighlty smaller (maybe 1/2 a mil) so you will have to bend the connection points within the socket a little to create a snug fit.
    BA20d Headlight Globe BA20d socket
    **Important**
    Regarding the globe above, it melted the plastic housing, see below. The globe is very bright and makes a big difference but I'm making the readers of this thread aware of the risk.
    Luckily I didn't go for a long ride otherwise the housing may have been melted through. As stated above, the stock bulb is .5mm wider in circumference which may help stop the bulb move around. I think I'll go back to a stock bulb.
    If you want to remain stock, Philips Premium BA20d bulbs are rated at 30% brighter than stock. In Australia Autobarn and Repco sell Philips bulbs.
    Park & Number Plate Light
    - T10 or W5W
    Aerpro sell a great T10 LED for the number plate - 3 x SMD
    You can also change your park light globe to something like this - 5 x SMD
    *Photos courtesy of myself, ModernVespa.com and DonsBulbs.com
    Hope this helps,
    Chritker
    Piaggio X8 250ie - 11g Dr Pulley Sliders - Michelin City Grips
    Next upgrade: Leo Vince exhaust
