Adding a extra battery Piaggio Fly 125cc
Last post 10-05-2011 12:28 PM by pyrah. 7 replies.
Page 1 of 1 (8 items)
  • 10-03-2011 04:40 AM
    Hello Forums..
    I am new to this..
    Question:
    I have a 12v 9amp battery, and i want to add 2 x 55w = 110w fog lights. Hella FF50
    My main light is a 12v 60w/55w (1 light bulb H4)..
    If i would look for an isolator how much more amps do i need and should i look for the same battery like the one i have.
    Can you please assists me.
    Thank you
    Zach
  • 10-03-2011 01:01 PM In reply to
    • Greg
    • Joined on 06-08-2008
    • Tuart Hill, Perth, W.A.
    • Posts 133
    Re: Adding a extra battery Piaggio Fly 125cc
     I doubt your charging system would handle that much extra load.
    Why do you need 2 fog lamps ?
    If it's extra light change headlight globe to +80 or +100% extra or crystal vision or H.I.D if there's room.
    Greg
    Yamaha Tmax 500, 2010 Black ... Sold her for ...
    Suzuki V-Strom 650 2012
    Perth W.A.
  • 10-03-2011 01:57 PM In reply to
    • wleung
    • Joined on 04-22-2009
    • Western Sydney
    • Posts 518
    Piaggiofly:
    I presume the simple answer would be - 110W / 12V = 9.2 Amps?
    Your charging system will need to support this extra load as well as any efficiency loss in the additional circuitry.
    Exs: CB250, GS500, DL650, Espresso 150, Triumph Street Triple, ZZR250, CB900F Hornet
    Current: CBR125R / Piaggio Fly 150 3V
  • 10-03-2011 01:58 PM In reply to
     Yep cant find the alternator rating but the main fuse is 15 amp so don't thing its big enough to charge 2 batteries . The 2 spots will take approximately 10 amp so on a separate fully charged 9ah battery will last less than 1hr . If you want  the spots so you can be seen then you could fit LEDs in them and run off normal electrical system
  • 10-04-2011 05:04 PM In reply to
    I would replace the stock H4 bulb with a Halogen bulb and try the extra light output you get before embarking on adding LED spotlights.
  • 10-05-2011 03:02 AM In reply to
    okay...get the point now,  their is no way to connect them...i have done some research..
    my alternator is not strong enought to cope with it......so how about 1 fog light...55w.
    http://cgi.ebay.com/ebaymotors/Single-CATZ-MSP-fog-light-Fits-PIAA-Hella-KC-Pilot-APC-/150436122386?pt=Motors_Car_Truck_Parts_Accessories&hash=item2306b10f12   (example)
    will this maybe do...
  • 10-05-2011 10:55 AM In reply to
    • Greg
    • Posts 133
    " Why do you need 2 fog lamps ? "
    Or even 1 ?
    Again, what is the need for fog lights ... as I mentioned about you can get a lot more light via other methods without inpacking the charging system ?
    Greg
    Perth W.A.
  • 10-05-2011 12:28 PM In reply to
     Piaggiofly have a read of this started by Who42 http://scootercommunity.com.au/forums/t/10538.aspx?PageIndex=1
