Bolwell Euro mx150 suspension
Last post 10-26-2011 07:02 AM by munnsi. 8 replies.
Page 1 of 1 (9 items)
  • 10-22-2011 06:18 PM
    Hello all,
    Bought a 2006  Bolwell Euro mx150 which seems fine except with 2up riding. I'm a 100kg but my daughter is only 60.
    The bike seems to be touching the frame or bottom half the time which obviously is not good. Has anyone changed or beefed up the
    rear shock on these? I think it is the same as the Sym Aprlia 150, if someone would confirm that and any other compatible models for parts.
    Help appreciated!!!
  • 10-22-2011 06:22 PM In reply to
    Re: Bolwell Euro mx150 suspension
    probably not a good idea to load up single shock rear with 160kgs, Im 130kgs and my aerox had a single that was maxed, never bottomed though.
    Slow Down & Enjoy The Ride
    2012 Kawasaki W800
    Go the Retro
    Looking for another BeeWee :)
  • 10-22-2011 08:55 PM In reply to
     Whats the max allowed weight in the handbook my Honda says 180 kg for example
  • 10-22-2011 09:50 PM In reply to
    Downloaded a Sym Euro MX user Manual but the controls look different to the Bolwell.
    All I found was 125kg net weight??? (Bike weight) I didn't think 160kg was too much for the tar. It carries us at a comfortable speed up and down
    I think their just soft and I think theres no pretensioner on it from a parts blowout.
  • 10-22-2011 10:19 PM In reply to
    • gaz
    • Joined on 11-04-2009
    • Posts 322
    Hi SteveMx,I have the same scoot & have occasionally ridden 2 up with likely the same weight but it's only bottomed out on a really hard bump so perhaps your suspension is a little worn
  • 10-22-2011 10:30 PM In reply to
     I would probably measure up the old shock absorber for correct length and bolt size . then look for an equivalent that as pre load settings on it
  • 10-22-2011 10:40 PM In reply to
     I have had one of these for nearly 20 000kms, never bottomed mine out but only had about 120 kgs with me and the daughter. Great scooter and very reliable.
    Enjoy the ride, maybe just needs a new shocky to fix this prob? How many Ks does it have?
  • 10-23-2011 08:57 AM In reply to
    Thanks for all that feedback fellas. I'm impressed with the response. It seems the spring maybe soft as its only got 6,000 on it or maybe there is some part of the frame grounding too early. Thought I'd get a few tips before I went digging. !!!!!
  • 10-26-2011 07:02 AM In reply to
    I have the same problem with my Euro Mx 150 and would also like a stronger rear shock.  Please let us know what you find.
