Top speed of 125cc scooter?
Last post 09-28-2012 08:07 PM by BBonered. 33 replies.
Page 1 of 3 (34 items) 1 2 3 Next >
  • 08-04-2012 06:01 PM
    Whats the top speed of your 125cc scooter,flat road but you can also mention downhill in here as well.
    I get 132km/h on the speedo with 9% disrepency which makes it 121km/h GPS and thats on the flats bouncing of the limiter...Of course,tested on the private track...Smile
    Ex Takegawa Pcx 170cc
    Ex Today 94cc Kitaco
  • 08-05-2012 05:39 PM In reply to
    Re: Top speed of 125cc scooter?
    on what?
    maybe your modified pcx, the the other scoot in your sig wont break a genuine 100km/h on flat ground
  • 08-05-2012 06:14 PM In reply to
     Sportcity 125 I would get 110kmph.  The Sportcity One would be aprox 95
  • 08-05-2012 07:08 PM In reply to
    andrewd:
    on what?
    Modified or not, it was a genuine question. Stock Pcx does 99kmh GPS, stock Sportcity one 125 did 98kmh GPS and the modified Honda Today did 105+ flats and more downhills...
    Anyway can you add any valuable info to the question asked?
  • 08-05-2012 07:12 PM In reply to
    Dakoda:
    That was a good 125cc, i wonder why they disappeared so soon from the showroom floors..?
  • 08-05-2012 07:16 PM In reply to
     Size and weight of rider ?
  • 08-05-2012 07:44 PM In reply to
    Yes,that would matter somewhat,good one Pyrah! I'm 85kg and 185cm long..:D
    Ladies you can skip on this info should you wish,no questions will be asked ;)
  • 08-05-2012 07:50 PM In reply to
    • TRA
    • Joined on 05-09-2010
    • Posts 302
    Lol, I was thinking that. Best I ever got from my too fiddy sportcity was about 120, mabe 130 if the wind was behind me and I was goin downhill.
    I am 6' and 100kg.
  • 08-06-2012 08:17 AM In reply to
    S
    Sorry I know its not anything to do with a 125 but I'm surprised a 250 isn't quicker that that! My Derbi GP1 only does an indicated 126 kph
    Derbi GP1 250i a properly fun scooter. Now totally renewed, rebuilt, run in, run Hard and now sold.
    Its name...The Flamenco Dancer by SOLD
    Now on a brilliant Yellow Suzuki SV650 NUDIST crumbs it don't half shift!
    Oh
    And remember boys and girls,
    Stock is BEST!
  • 08-06-2012 09:14 PM In reply to
    lead runner:
    S
    I know of a 300 Super Sport with Polini 6 roller variator that will do 150kmh on the speedo also has akrapovic exhaust. I also knew of 250 Quasar that could do 140ish again speedo indicated running Polini 9 roller variator. So something is not right with you vario, maybe flat rollers,worn out belt etc etc. Ive heard all the best for 6 roller Polini vario with quassar engines,i'd get that perhaps before an exhaust upgrade if your hunting more performance plus its a cheaper first step....
  • 08-07-2012 06:48 AM In reply to
    the 9 roller was only fitted new on 22/6/'12
    they say speedos can be out maybe mines out in the other dirrection Yes
    Oh
    Stock is BEST!
  • 08-07-2012 02:24 PM In reply to
    Problem is you need to get to the bottom of what weight rollers are installed in the variator. Normally installing a variator is step 1, after this you look for the speed balance you're after. In your case it would seem like 130 + is where you are wanting to be. So you will need to tune it to do that. I remember riding a standard GP1 which did have an indicated top speed above 126. So could be a number of things happening in your transmission.
    After this it will come down to the fact that at high speed one thing could be slowing the scooter a little, and that one thing is you. GP1 is sporty, has a little screen so you're perched up and in the air. The best thing I remember about the GP1 was the handling. It was certainly not suited to freeway work.
  • 08-07-2012 03:47 PM In reply to
    hondatodaydemon:
    Really?  I mean, really?  The hottest GTS I know of has hit about 92mph / 148 kmh (GPS verified, but my memory is hazy on the exact speed).  That's a 244cc GTS upgraded with the full Malossi 4v and 269cc kits and some pretty experienced fettling.  I've seen close to 135kmh indicated - my speedo error that's maybe 122kmh - on my stock GTS 250 (244cc) which actually makes 0.4kw more than the stock 278cc "300". (Details: stock GTS250 w flyscreen, Bitubo suspension, 72kg rider, full tuck, fullface helmet, flat road - some downhill in gaining speed)
    I'm pretty skeptical about the impact of variator tuning and gearing on real-world top speed.  Eventually it's all about the peak power of the motor vs the drag on the scoot - sure, you can mess it up with gearing, but you can't take a machine higher than the urge its power actually produces.  I've just spent a week out-running an X7 300 on hilly and open roads to prove that point (mind you, the X7 was a whole lot more stable at speed!!)
    Sydney / Vespa PX150 & GTS250ie / BMW R1200R
  • 08-07-2012 04:38 PM In reply to
    Caroanbill:
    So speedo woud have been indicating 160+kmh considering they are considerable ammount out,so whats so unbelivable a 300cc with a new grease trap 6 roller polini variator and a decent akrapovic exhaust pumping some real speed of 135ish GPS or 150kmh speedo indicating?
    I get 121kmh GPS out of my 125cc so surley there is nothing unbelivable of seeing a 300cc doing 135kmh easy with some small modding..Sometimes doing bigger bore,head etc etc (tricky to tune to full potential)  may not give you waaay extra top speed but accelaration would have improved considerably i imagine.
    I might have been slightly unclear about 250cc qussar when i said 140ish,that was just a rough indication as it could have been 140-1 or 2kmh so thats still only 125+kmh at least GPS which is what you would excpect out of 250cc at least (polini variator), also what is a torque output of 250cc to 300cc? Torque is what is needed to get you across that line...
    Caroanbill:
    Made a world of diff on my PCX, coupled with aftermarket face pulley that also has a diff face angle to squezee belt further up it has given me an amazing results,but without a hotter camshaft i would not have been able to reach those speeds without full tuck or slipstreaming or slight down hill advantage,camshaft made a world of difference...
  • 08-07-2012 04:54 PM In reply to
     Aerodynamics one of the main things believe the record on a bike is 167 MPH
