No power on my scooter
Last post 08-03-2013 05:20 PM by Blam. 5 replies.
Page 1 of 1 (6 items)
  • 07-11-2013 10:20 PM
    • Waz
    • Joined on 07-08-2013
    • Posts 2
     i can't get any power on my scooter. The battery is fine and the fuse is ok, so it must be some other issue. does anyone have any tips? thanks
  • 07-12-2013 04:46 PM In reply to
    Re: No power on my scooter
    check that the battery leads are tight and clean try maybe loosening them or even take them off and clean with a small piece of emery paper or similar then put back ensure tightness....give that a go....free to do...Wink
    ....lets have another drink...
  • 07-14-2013 08:35 AM In reply to
    • Blam
    • Joined on 08-25-2008
    • Posts 437
    Does the scooter have a cut off switch? Some scooters have a side-stand cutoff switch. Knowing what scooter you have might help narrow your problem down.
  • 07-14-2013 06:16 PM In reply to
    • Waz
    • Posts 2
     Thanks for the tip. I gave them a good clean and now i have power but not enough to start the bike. I will need to tighten them - Ive lost the little nuts that fit into the battery ,where the screw goes in. I tried the auto store but they didnt have any. any idea where i can buy them? The bike is a torino 125c
  • 07-14-2013 08:10 PM In reply to
    Waz,if you know someone that owns a battery charger try to borrow it to charge your battery....you will then know if money spent on a new battery will be worth it...
  • 08-03-2013 05:20 PM In reply to
    • Blam
    • Posts 437
    Battery connections have to be tight. Always. Tighten those battery connections right down and you'll be surprised.
