GTS 300 headlight adjustment
Last post 05-11-2015 07:16 PM by DaveO. 5 replies.
Page 1 of 1 (6 items)
  • 03-18-2015 03:50 PM
    • DaveO
    • Joined on 10-13-2010
    • Cow Flat NSW
    • Posts 290
    I'm told my headlamp is dazzling, even on dipped beam.
    The handbook refers to an adjusting screw under the headlight, but the only one I can see, a black phillips-head screw, seems to be a securing screw: clockwise it tightens up and anti-clockwise it comes out. Anyone got any ideas what I'm missing?
    The Red Menace
  • 03-18-2015 04:14 PM In reply to
    Re: GTS 300 headlight adjustment
    Haynes manual shows it as the adjuster screw located below the headlight
    Adjust after checking tyre pressure  & suspension is set right on level ground with assistant sat on seat
  • 03-18-2015 07:50 PM In reply to
    • DaveO
    • Cow Flat NSW
    • Posts 290
    Hmm. There's no sign of a screw there, just a hole in the plastic. I can't look inside because the front panel is in the way. Does the Haynes manual explain how to remove it?
    The Red Menace
  • 03-18-2015 09:11 PM In reply to
    NO the manual was printed to 2010 so either they have modified the scooter light adjustment method or your screw as fallen out hence the beam settings
  • 05-08-2015 09:55 PM In reply to
    How far away did you buy it Dave? Get the dealer to have a look at it....Hmm
    ....lets have another drink...
  • 05-11-2015 07:16 PM In reply to
    • DaveO
    • Cow Flat NSW
    • Posts 290
    I finally sussed it out. The angle of the adjusting screw, deep inside its little hole is such that you need to remove the horn cover to see what you are doing and get a screwdriver on it.
    The Red Menace
