Ignition Conversion Vespa Sport 150, 1960 ish model
Last post 09-21-2015 09:04 AM by Mike Holland. 2 replies.
Page 1 of 1 (3 items)
  • 09-19-2015 07:15 PM
    • Kiwi
    • Joined on 05-30-2012
    • Posts 2
    Hey Everyone out there...
    Curently underway puchasing the above Vespa. Will not be an everyday runner, pretty much just a Summer weekend runner. To make it more relaible, am thinking of converting it to electronic ignition. 1/ Has anyone carried out a conversion?  2/ Where can i purchase a kit preferably a non Asian variety? 3/ Pro's and Cons or suggestions greatly appreciated???...
    Kiwi
  • 09-19-2015 07:34 PM In reply to
    Re: Ignition Conversion Vespa Sport 150, 1960 ish model
    With modern two stroke oils, the original ignition system should be fine.
    Use any JASO FC oil and fouled sparkplugs will be a thing of the past, I use Castrol.
    If anything needs upgrading, then a new NGK spark plug, cap and lead should be enough without risking the conversion to a CDI.
    If the spark from the old system is a bit weak, closing the gap by 30% will lower the stress on the system and keep it reliable. In the old days larger gaps were needed to cope with plug fouling from leaded petrol and thick oils.
  • 09-21-2015 09:04 AM In reply to
    I hope you can find some easy kit to do the conversion. I converted my Vespa Rally180 to electronic ignition, but just by fitting the components for the Rally200 electronic that came out a few years later. Never had another backfire after that. Conversion is definitely worth while for good, reliable running.
    I also converted my Rally to 12 volt electrics, by fitting two 6v headlight coils in series to power everything.
