Modding my new GTS300
Last post 11-04-2017 08:04 AM by aspro boy. 104 replies.
Page 6 of 7 (105 items) « First ... < Previous 3 4 5 6 7 Next >
  • 02-19-2017 08:19 PM In reply to
    Re: Modding my new GTS300
    Rod Fountain:
    Pull over rider says that tall slender uniformed gentleman with his sunnys on and cap pulled well down over his forehead --Licence please--Is that really the year you were born ??? better blow into this bag and run this applicator over your tongue a couple of times
    Have you been drinking or taking illegal drugs because guys of your age dont normally ride at that speed
    I clocked you at 70klm over the speed limit and on a vehicle of that size its a wonder you didnt blow the engine up
    Wheels of that size are not meant to rotate that quickly
    So please step over here and put your hands behind your back
    Not just the oldies Wink
    Image result for scooter stopped by police
  • 02-23-2017 11:33 AM In reply to
    So no nasty surprises Rod? When you get time, you should write up a point  inventory of your upgrade(s). Then include what is remaining that you would like to undertake  ... for those of us who love the personalized ride(s).
  • 02-23-2017 01:29 PM In reply to
    Rod here -- I didnt mod anything --I think its Mike who should be doing a report --but then it might take a lot of fun out of it
    riding for fun
  • 02-23-2017 05:03 PM In reply to
    OK, here goes. Mods so far  --
    Remove all the excess chrome Vespa and GTS300 emblems on the sides
    Remove the front mudguard reflectors
    Bitubo front shock
    Brembo front brake caliper
    Old style GTS front mudguard ornament - no black plastic
    Headlight chrome rim
    FAR black mirrors
    Leather lever covers
    Audicator turn signal beeper
    Solo saddle  -  further modified to remove hump
    Topbox
    Akrapovic exhaust
    Air filter mod
    Earlier GTS tail light - no chrome rim
    Malossi V4 282 cc cylinder and piston and head
    Malossi RS24 rear shocks
    Malossi red clutch springs
    Malossi Lambda Emulator
    NGK CR8EKB plug
    Fuel injector IWP158
    Polini 6-roller variator with 12.5 gram rollers
    Wasp emblem on the back of the topbox
    In the pipeline,I have a later GTS300FL horn cover, the Vietnamese version, waiting to be painted matching blue. The 12.5 gram rollers might be replaced with 13.5gram ones, as I feel the engine is revving a bit high. I miss the rev counter that the 250 had. And the Akra seems a bit loud (maybe because the engine is revving harder?), and I might re-pack it. But I need to re-check those inaccessible nuts that hold the exhaust manifold on first.
    Just topped up the crankcase oil. The engine is burning oil like a two-stroke, but that is normal for a new Malossi kit. Should settle down quickly.
    I think that covers everything.
  • 02-23-2017 06:45 PM In reply to
    So besides going like a rocket, it'll look good too
  • 02-23-2017 09:24 PM In reply to
    Sorry Mike, as soon as I walked away from the computer it occurred to me that I had my wires crossed. Very impressive. With that level of adeptitude, and passion, I should have purhased your 250, which as you pointed out was good buying.
    Thanks for posting this. I will study it in detail just for the knowledge of it.
  • 02-23-2017 11:33 PM In reply to
    aspro boy you should have bought Mike's old one
    Image result for Mike Holland vespa
  • 02-24-2017 09:00 AM In reply to
    Except that a lot of the mods that were on that bike are now on the new one  -  Brembo caliper, Malossi rear shocks, Malosi V4 cylinder head, headlight rim, Audicator, leather lever covers. But she sure was beautiful  -  won the concourse d'elegance at the Sydney scooter rally.
  • 02-24-2017 09:53 AM In reply to
    Sure looks good in that livery  ... I had noted earlier that mods. had been removed. I'm not a red sort of guy, but the vintage red looks awesome, especially with the accents. So my eye for detail tells me that you have a spare wheel set Mike?
  • 02-24-2017 10:51 AM In reply to
    Why are Fire engines always red
    Because they are always Russian
    riding for fun
  • 02-24-2017 11:54 AM In reply to
    No extra wheel sets. I had the original wheels painted by Collide-a-scope, and then stuck silver vinyl strips around the rims.
    I would like to have the wheels on my new scooter painted matching blue, but it is a bit expensive. One day, when I am feeling rich!
  • 09-09-2017 03:04 PM In reply to
    No updates since February, so here goes.
    Snipping that wavy oil ring was a mistake. The result was that the scooter burned oil like it was going out of fashion. So I ordered a new set of rings and did the job again. Scooter now runs beautifully and doesn;'t use any oil. Had a problem with the Polini variator - caused belt rubbing which damaged the sump seal causing the inevitable oil leak. I am now using 13 gram Dr.Pulley sliders, which are nearly as good but don't give me that "kick": on take-off. Will try the Polini again soon, with a fatter fuzzy washer in the variator.
    Latest mods have been cosmetic  -  painted the wheels to match the scooter, replaced the horn cover with the later version which is much more elegant, and replaced the knee pads with metal ones painted to match. Also fitted a wavy brake disc tthe front, and the old style tail-light without the chrome surround.
  • 09-09-2017 10:46 PM In reply to
    Just a thought.....although those black mirrors look pratical and quite good, how would you feel about chrome ones?
  • 09-10-2017 09:00 AM In reply to
    Why, Martin? Are you after my black ones?
    As this scooter came out of the shop, it looked like a Christmas tree ornament with all the bits of chrome on it. The mirrors, the taillight surround, the bezel around the speedometer, that kitsch chrome tip on the exhaust outlet, plus all the writing stuck on the panels. So the first thing I did was de-chrome it, and the horrible lollipop mirrors were the first to go.
    The chrome might look gooid with some other colours, eg black or silver, but not with this bright blue. It was just too gaudy.
  • 09-10-2017 11:26 AM In reply to
    Ok...
