Honda NH80 restore- carb/pipe
Last post 05-17-2016 10:48 PM by INMA. 8 replies.
Page 1 of 1 (9 items)
  • 05-17-2016 01:21 PM
    • nixon
    • Joined on 11-02-2012
    • Posts 4
    hey people
    Well, already own 3 other bikes, 900, 750 and a 250..but ive always had a soft spot for 2 stroke scooters so when I came across a 87 in decent nick i thought i could make a little space.
    Getting ready to fire it up, cleaned oil/fuel tanks, airfilter was dust etc.
    If it runs good enough, great..but does anyone have experiance on carbs or pipes for these? stock is a tiny 16mm carb..80 dirt bikes are 24mm.
    Not looking for huge gains..just flow the lil 80 better
    im in melbourne FWIW
  • 05-17-2016 08:55 PM In reply to
    • Posts 842
    Re: Honda NH80 restore- carb/pipe
    There is not much you can do with the NH80 honda. The NH125 is a much nicer machine with its extra power.
    That model Honda was never raced so there is not much data on getting more power or tuning the transmission.
    All automatic scooter modifications start with tuning the transmission to get the most from the engine, then work on the engine is possible.
    Stupid registration costs in Victoria make the value of running an 80cc scooter a very expensive exersize for not much performance.
    Just a bigger carby on a NH80 would not make more power because the porting and exhaust are big restrictors. The trick tuning two strokes is building an engine with a higher speed powerband and tuning the transmission to keep the engine working in that powerband.
    If you could buy the bits for more power and transmission control, it costsfrom $500 to $2000 depending on your skill level. If you are registering the scooter, its cheaper to buy something like a second hand stock Yamaha 250 which is better and similar cost.
    I'm in Melbourne and would be happy to talk more on my development of my Zuma which was built for giggles.
  • 05-17-2016 08:56 PM In reply to
    • Posts 842
    Forgot to mention you may be able to use club registration.
  • 05-17-2016 09:21 PM In reply to
    • nixon
    • Posts 4
    Appreciate the input. agree the pipe is where biggest gains may found.
    wow a lot more $$$ than i figured
    maybe a cr80 etc pipe? they go hard!
    re transmission, do you mean different weight rollers?
    well got it running easily, idles nice. all lights etc work.
    noticed the oil pump cable snapped so ran 25 - 1 premix till get new cable
    ill get a new tyre and see how it goes. If it goes 70 ill be impressed
  • 05-17-2016 09:56 PM In reply to
    • Posts 842
    It will do 70.
    Variator weights adjust the engine speed governed by the transmission. My variator is different, the weights don't slide and there is no cam profiles to wear, so the speed control is a lot better than other variators.
    The centrifical clutch engagement speed allows the engine to disengage at idle then rev up to the powerband slipping the clutch so the engine power is enough to move the scooter until the scooter is rolling and the clutch locks.
    The torque driver that slows the engine speed at low loads and lets the engine rev at high loads.
    The variator cam profile that controls engine speed as road speed changes.
    Lots of adjustments to change the characteristics of the transmission to suit the scooter and engine.
  • 05-17-2016 10:17 PM In reply to
    • nixon
    • Posts 4
    thanks!
    good to be aware.
    i  maybe competely fine with how fast/slow it is. i do have a 750/900 for longer high speed trips
    but if i do want to tune/ improve do you recommend any scoot/2 stroke gurus in melbourne?
    ive heard of scooterlabs but thats it
  • 05-17-2016 10:19 PM In reply to
    • nixon
    • Posts 4
    how does your zuma go? its a 68cc? sounds like fun
  • 05-17-2016 10:37 PM In reply to
    • Posts 842
    My ride to work was a Kawasaki ER5 until a car banged us up. My shoulder can't take the motorbike anymore so the lighter scooter gets me to work. The Zuma is a fat wheeled scooter that handles better than skinny tyres.
    The simplest way to get a cheap performance scooter is to start with a model that has been raced in Europe because there will be a selection of good parts at value prices. Yamaha and Aprilia watercooled models are the best place to start if you must play with a scooter.
    Compared to any motorbikes, scooters are sedate, I built mine cheap to get to work. I'd ride my son's Kawasaki 250 but I don't have the strength.
    i
  • 05-17-2016 10:48 PM In reply to
    • Posts 842
    Forgot to say the 68cc keeps up with traffic with a practical cruise speed of 60 to 70 km/hr along Beach Road. The transmission is tuned so I can go flatout and it remains smooth and safe.
    It has spat me off in front of the house starting cold and the transmission belt slipped, the engine hit the powerband, front wheel up and dropped on its side with me feeling like an idiot. Its got enough power to do wheelies etc. but the clutch is adjusted to keep the engine off the powerband till about 30km/hr.
    Top speed is unknown, I've seen 10,500 rpm uphill which is 90km/hr still accelerating but the engine is really limited to 9000 rpm. If you pay the bills and can live with replacing pistons regularly, then higher RPMs can be set in the transmission but the power has a price.
    Its basically cheap transport (fun)for a old biker.
