My Honda nut inside the bars (inner weight) was held by a spring clip engaged in a hole in handlebar hidden by the rubber grips . Buy removing rubber grips could push it back through hole and pull out assembly . Some others makes i believe have a welded nut inside handlebars that have to be drilled out
