Akarapovic exhaust
Last post 12-23-2016 12:12 PM by Mike Holland. 3 replies.
  • 06-29-2016 03:35 PM
    Akarapovic exhaust
    Hi all hope your rides are safe and warm. I am very interested in replacing stock exhaust with akrapovic question (ftom a novice) is it literally as simple bolting on, nothing else required? Many thanks in advance 😎
  • 06-29-2016 05:02 PM In reply to
    Re: Akarapovic exhaust
    Yep there slip on models should be a straight swap
  • 12-13-2016 09:21 PM In reply to
    You won't get any real extra performance out of a slip on.
    Some nice noise and a reduction in weight from the stock anchor is probably the sum of the gains.
  • 12-23-2016 12:12 PM In reply to
    If you are unlucky you might have to loosen the exhaust manifold where it bolts on to the cylinder and adjust its position, to get everything to line up right without any stress anywhere. A bit of a bugger to get to those nuts.
    No stress is very important for handling the vibrations, otherwise cracks will develop.
    And I am certain my scooter is nippier with the Akra, especially with the catalyser removed  -  but then it gets too noisy. All the German tuning experts fit Akras or Remus exhausts. They test their mods on dynos, and none of them use the strandard exhaust. But on the other hand, they have a lot of mods to the engine, airfilter, etc to go with the easier flow exhaust. I have a modified airfilter and modified injector fuelling on my GTS300.
