Angled Tyre Valve Extenders
Last post 11-29-2016 10:14 PM by pyrah. 5 replies.
Page 1 of 1 (6 items)
  • 11-25-2016 09:43 PM
    It was such a phaf trying to check the tyres today on the little Dio. Can someone advise me regards a good valve extender and whether or not it might affect the balance of these narrow 14' wheels. Thanks
  • 11-25-2016 09:50 PM In reply to
    Re: Angled Tyre Valve Extenders
    Yep Ebay cheap around $4.50 or around $1.60 same ones from china but just use them when inflating tyre then screw off again
    Image result for angled tyre valve extension
  • 11-25-2016 10:36 PM In reply to
    There are also pressure gauges inflator that clip on to forecourt air lines that might help you $23.95 from Peter Stevens
    Image result for tyre pressure gauge
  • 11-27-2016 03:15 PM In reply to
    The angled dealies that screw on/off are pretty good - If you get angled valve stems put on at your tyre change, it won' throw the balance of the wheel off, as hopefully the shop balances everything when they do the tyre. My SYM has had angled stems since new. They make the job a LOT easier.
  • 11-29-2016 08:06 PM In reply to
    Some thoughtful advise here. Thank you.
  • 11-29-2016 10:14 PM In reply to
    aspro boy:
    Devil Dio with a 16 inch front wheel may help access Stick out tongue
