Spray oaint
Last post 02-07-2017 03:49 PM by Giulio. 18 replies.
  • 01-08-2017 05:13 PM
    Spray oaint
    Hi all hope holidays where safe an fun my question is how cans of spray paint to complete an entire Vespa px. Many thanks😎
  • 01-09-2017 08:24 PM In reply to
    Re: Spray Paint
    Don't know exact numbers but will you need primer top coat and clearcoat Smile
  • 01-10-2017 09:07 AM In reply to
    Re: Spray Paint
    Thanks pyrah I'll go with four and hope for at least two coats
  • 01-10-2017 11:59 PM In reply to
    Re: Spray Paint
    To paint a whole scooter, it needs to be properly prepared.
    Then you'de need 4 cans of undercoat etch primer, then 6 cans of fill primer and 12 cans of color followed by four cans of clear.
    All based on you having a smooth finish following expert preparation.
    And it will probably look like crap.
  • 01-11-2017 10:37 AM In reply to
    Re: Spray Paint
    Why should it look like CRAP if he uses all those cans of spray on it --unless he is painting it nipple pink or lemon yellow
    riding for fun
  • 02-05-2017 06:06 PM In reply to
    Re: Spray Paint
    you will get orange peel spraying out of cans sometimes the paints neary dry before it get to the panel your spraying try to spray in low humidity that seems to help and preperation is half the key l used 3 cans of undercoat 6 cans of emamel never used clearcoat on it hope this helps
  • 02-06-2017 12:41 AM In reply to
    Re: Spray Paint
    Thanks beakeyozz will bear that In mind and yes I know preparation is key have started with sander and will get to it with emery paper soon enough. Not too concerned with end result. A it's my first attempt. B. The finish I'm after doesn't need to be perfect. Under coat, primer and top coat will all be dealt with. To be honest at this stage it's the doing rather than the finished product, although I'm sure that will change soon enough. Thanks again for input and advice😎
  • 02-06-2017 10:36 AM In reply to
    Re: Spray Paint
    Top marks for having a go -as Malcolm Turnbull would say "thats initative ".If it finishes looking like SH---T then dont worry because it will fit right in with the way the world is going these days
    riding for fun
  • 02-06-2017 11:29 AM In reply to
    Re: Spray Paint
    dont know if this pic worked
  • 02-06-2017 12:05 PM In reply to
    Re: Spray Paint
    Thanks Rod yes kts face it even if I get the thing working chances are they'll become illegal before I can register and ride. Thanks beakeyozz no pic didn't work😎
  • 02-07-2017 08:49 AM In reply to
    Re: Spray Paint
    You don't want to spray in this hot weather, because the paint dries too fast and doesn't have time to flow together for a nice gloss finish. .Had this problem with some of my models, and I paint in the evening rather than in the heat of the sun.
    But once it is touch dry, the sun is good for baking it.
    Edit: doesn't matter for the undercoats.
  • 02-07-2017 09:21 AM In reply to
    Re: Spray Paint
    Thanks Mike good advice will keep that in mind😎
  • 02-07-2017 10:17 AM In reply to
    Re: Spray Paint
    Have a search for rattle can spraying for tips from the USA
  • 02-07-2017 11:00 AM In reply to
    Re: Spray Paint
    When you have finished on the VESPA there are still plenty of railway carriages to practice on--inside and out
    riding for fun
  • 02-07-2017 12:51 PM In reply to
    Re: Spray Paint
    Funny you should say that Rod last week in WA a train about 1 km long past and every ore tub was covered in graffiti
