Piaggio Fly - clutch clean
Last post 02-02-2017 05:40 PM by sam77. 3 replies.
  • 01-11-2017 05:22 PM
    • sam77
    • Joined on 04-17-2011
    • Posts 34
    is there an easy way to clean the clutch without taking it apart ? i've read i can take the outside cap off
    and spray it with brake cleaner ?
  • 01-23-2017 05:03 PM In reply to
    Re: Piaggio Fly - clutch clean
    Think you will need to remove transmission cover to clear out any dirt grease you displace Sad
    Image result for super cheap brake cleaner
  • 01-23-2017 08:17 PM In reply to
    • Posts 842
    If its a dry clutch, then simply removing the cover and hosing out the backof the transmission section will clear the dust from the clutch.
    Most standard transmission services  include lubricating the variator weights. Don't get water on the variator.
    And when its all done make sure you get rid of the water then give it a run to get everyting hot to expell any water that might remain.
    Don't blow air over the transmission unless you have a control on the dust, the dust is very bad for your lungs.  I know asbestos is banned in Australia but any parts made inChina are a risk, don't trust them.
  • 02-02-2017 05:40 PM In reply to
    • sam77
    • Posts 34
    I used some wheel cleaner. Took the cap off and flushed it out. Lots of dirt came out and good as gold now...
