Squeaky Disc Brake
Last post 10-09-2008 11:42 PM by E2W. 16 replies.
Page 1 of 2 (17 items) 1 2 Next >
  • 12-25-2007 07:50 PM
    Squeaky Disc Brake
    For a while now my disc brake (the front) has been squeaking like a mouse wheel. At someone's suggestion I gave it a wipe down incase there was dust on it but there hasn't been a noticable difference. I was just wondering if there was anything else I could do?
  • 12-25-2007 08:23 PM In reply to
    Re: Squeaky Disc Brake
    Not sure about your scooter,  but I had a Holden Commodore that used to do that from new,  eventually (after about 10 months of my bitching) GMH came up with some spring shims that fitted between the brake pad and disc brake piston.
    Apparently on the Holden, the awful squeaking noise was actually caused by the disc brake pad vibrating !!
    EDIT:
    Another thought,  I have a feeling there is also a "grease" type material on the market to stop that noise, that you wipe over the back plate of the disc pad,  the part that is in contact with the disc brake piston,  NOT the side that faces the disc rotor,  might be worth a visit to check out your local Repco store....
  • 12-26-2007 04:20 PM In reply to
    Mine squeak on the Bee Wee, I dont thik its anything major! But I want a whole break check soon anyway (Gives Brendon the look)
  • 12-28-2007 11:30 AM In reply to
    ScootaNut:
    Couple of things:
    1) when in motion (and NOT in traffic!) apply the brakes quite strongly a few times - this can help take the squeak away.  Being gentle with disk brakes seems to encourage squeaking for some reason unknown to me
    2) you can apply an anti-squeaking paste to the back of the brake pads.  Unfortunately you have to take the pads off first which is a bit of a rigmarole, paint the stuff on, let it dry and then hope that the squeal disappears.  It normally does, but its a bit of a palaver.
  • 12-28-2007 01:41 PM In reply to
    this will most likely be normal brake pad on disc noises and nothing to worry about. Is it only when applying the brakes that the noise happens. If so not anything to concern yourself with
  • 01-05-2008 02:12 PM In reply to
    Steve is on the money, the number one reason a front brake will squeak is the nut between the handle bars and the seat. The Montego doesn't have squeaky brake pads so go with Steve's suggestion of a couple of hard brake applications and report back.
  • 01-21-2008 09:50 PM In reply to
    Scooter HQ:
    LOL a bit like the "OE" error ITs talk about? it's just a shame I've only just seen this response :)
     all the sadder since the new Fly, atleast the demo, doesn't seem to have the squeak.
    btw - I tried hitting the brakes hard whenever I could, with no traffic around, & it didn't seem to stop the squeak completely although I think it may have reduced it.
  • 01-22-2008 11:15 PM In reply to
    ScootaNut:
    Scooter HQ:
    Don't you mean the i d ten t error or the ebkac error that IT staff will talk about? Wink Big Smile
  • 10-07-2008 11:13 PM In reply to
    • Pegasus
    • Joined on 10-18-2007
    • Kingsley, Perth. WA
    • Posts 1,041
    This is an old post but I thought I might as well add my bit to the end of it in the hope someone will see it.
    I did the right thing and did my research on SC first but only 6 responses came up.
    The rear brake on the X8 sqeaks so loud it drives me insane. I almost feel embarresed to brake when approaching traffic lights which obviously is not a good thing. I know it's nothing to worry about but a quieter brake would be nice. I'll try the hard braking first to clean the disc and/or pads. Any other ideas anyone?
    Ride safely everyone.
    Piaggio X8 250ie
    38,000km
  • 10-07-2008 11:14 PM In reply to
    Oil?
    ONLY JOKING!!!
  • 10-08-2008 01:47 PM In reply to
     When I change pads on anything I chanfer the pads (this isn't esy to explaine), I take the leading and trailing edge of the pads with a file(DONT TRY THIS AT HOME KIDS) because when the pad has a right anglecontact to the disk it promotes a vibration ofter refered to as break squeel.It is an easy fix and just a case of wipping your pads out and chanfering them and pop them back in.(20 min job)
    Select Scootas
    www.scoota.com.au
  • 10-09-2008 11:08 AM In reply to
    • Pegasus
    • Posts 1,041
     Thanks for that bit of advice Service. Seeing as I don't know how to remove the brake discs I'll remember that for the next time I get the brakes done.
    Piaggio X8 250ie
    38,000km
  • 10-09-2008 11:51 AM In reply to
    Pegasus:
    Just the pads , no need to touch the diskCool
    Select Scootas
    www.scoota.com.au
  • 10-09-2008 12:00 PM In reply to
    • Pegasus
    • Posts 1,041
    Service@Bolwell:
    Oops. Sorry Service. I meant the pads. I don't know how to remove them either.Embarrassed Is it something someone with a little bit of mechanical aptitude can do?
    Piaggio X8 250ie
    38,000km
  • 10-09-2008 01:42 PM In reply to
     Yes and no... They are your brakes and if they fail you may be killed...
    Dont mess with them
    Select Scootas
    www.scoota.com.au
