Stuck at the lights.
Last post 09-26-2010 02:39 PM by hcrun. 25 replies.
Page 2 of 2 (26 items) < Previous 1 2
  • 02-18-2008 09:15 PM In reply to
    • Keeper75
    • Macarthur, NSW
    • Posts 627
    Re: Stuck at the lights.
    sodarocks:
    Also as a new rider it is so hard for me to work out where the oil drops are
    They are down the centre of the lane and more concentrated at traffic lights and near bumps. If the road surface is good you can ride in the right wheel path of where a car would be. This means you are not letting car push by you in your own lane and the car tyres are doing some of the work in cleaning the road surface a little. It's not perfect but where you position yourself in the lane is important and depends on different things at different times. Good rider training should cover lane positioning.
    A bartender is just a pharmacist with a limited inventory.
  • 02-19-2008 10:14 AM In reply to
    • Pegasus
    • Joined on 10-18-2007
    • Kingsley, Perth. WA
    • Posts 1,041
    I ride a Piaggio X8 250cc which is a fairly heavy scooter and I regularly go through an intersection in Main Street where it happens even on my heavier scooter.
    If I'm the only one approaching the intersection I go down the middle and sort of zig-zag the last 2 metres before I stop. That seems to cure the problem.
    Thanks for the tip of the number on the traffic light box. That hadn't even occurred to me.
    Ride safely everyone.
    Piaggio X8 250ie
    38,000km
  • 09-24-2010 08:55 PM In reply to
    found another scooter un-friendly intersection. In Freo on Queen St. 10m or so from Frank's The Scooter Shop. The first set of lights after the bridge, turning right heading towards the markets. Mate & I had to wave a cager forward to trigger the lights, after watching the lights cycle a couple of times without giving us the green arrow, but not surprisingly she was unwilling after cutting across two lines of traffic to get in the filter lane, almost wiping us both out just to try to get infront of the "bloody scooter" riders. it took some encouragement for her to move forward & trigger the lights. She did it eventually.
  • 09-24-2010 10:35 PM In reply to
    • niks
    • Joined on 01-22-2009
    • Melbourne
    • Posts 1,114
    If you glue a powerfull magnet to the underside of your scooter so it wont come off if you hit a big bump, you will find that this will activate the sensor.Yes
  • 09-24-2010 11:04 PM In reply to
    niks:
    No it won't. Read all about it: http://message.snopes.com/showthread.php?t=16531
  • 09-24-2010 11:51 PM In reply to
    • TRA
    • Joined on 05-09-2010
    • Posts 302
    niks:
    Nope, the sensors are an inductive loop. They are a single wire loop in the road and to change the inductance of the loop you need a big chunk of ferrous material. Think of its as a large metal detector.
  • 09-25-2010 12:23 AM In reply to
  • 09-26-2010 07:31 AM In reply to
    • hcrun
    • Joined on 05-23-2010
    • Canberra
    • Posts 431
    Notice how the d***head demonstrating the use of the magnets (in the video) is wearing all his PPE......shorts, sneakers, T-shirt and hair. Confused
    Mid-life went past too quickly so I'm having a late-life crisis.
  • 09-26-2010 11:30 AM In reply to
    • niks
    • Melbourne
    • Posts 1,114
    hcrun:
    And what right have you to judge someone. Some people are fortunate to not live in a nanny state that tells them what do 24/7 and lets them use their free will to make choices so they can learn the lessons of what they create by their choice.
  • 09-26-2010 01:52 PM In reply to
     Freedom of choice Yes
  • 09-26-2010 02:39 PM In reply to
    • hcrun
    • Canberra
    • Posts 431
    niks:
    Ohhhh, about the same amount of right as you do and, judging by most of your posts herein, you certainly do more than your share of handing out judgements left, right and centre to not only politicians and bureaucrats but also anyone else who doesn't toe your party line.
    So don't look down your nose at me, sport. Clean up your own act.
    Bruce
