New aerox build up
Last post 05-01-2010 10:09 PM by bpt4w. 96 replies.
Page 2 of 7 (97 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 09-24-2008 01:13 PM In reply to
    • waxhead
    • Joined on 12-17-2007
    • gold coast
    • Posts 882
    Re: New aerox build up
    well its going with the 70cc kit and the c-16 on it
    ihave sort of tuned it up
    i didnt do the cases this time i will do it when i pull the bottom end down
    which i think at 10500 rpm is not going to be long
    it goes not bad at all but gezze the noise from the scooter at that rpm is a bit much
    the clutch weights are way to soft and i need to tighten them up to help it get up on the pipe
    i think its going to go quite hard when i have finished
  • 09-26-2008 09:31 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    well i lightened up the rollers and saw a 12600rpm on the tacho
    i think the 50cc stock crank life could be measured in minutes at that rpm
    so its time for the 12mm to go in
    well soon anyway
    I was going to put the stroker in but it makes the transfer way to high at 45mm stroke
     the 21mm delorto i am using is a great carb and very easy to tune
    its my recomandation for the street
     Ok well anyway , back to playing with it
  • 09-29-2008 11:38 AM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well hooked up one of my jetski ignitions to it
    Made a big difference and its hitting heaps harder now
    Just need to work on the top timing curve and will be awesome
  • 09-29-2008 01:06 PM In reply to
    HOOWEE!!!  This could be looking into a big showdown between the Typhoon of jason and the Aerox of Wax. Can't wait to see the final result on the track.
  • 09-29-2008 01:59 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Hell no
    his thing his nuts
    mine is way more mild than that
     springs turned up but werent the right ones
    im looking for some black mhr delta springs
  • 09-29-2008 08:41 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    I pulled tghe piston out to have a check on it
    Im not sure the crank is liking the 12000 rpm iuts getting at the moment
    Its lucky its a low k bike
    I have a bgm crank out of my scp runner and i have pulled that out
    over the next holidays i will put it in as well as port the cases
     Damn the advanced timing brings on the power early
    I think i maybe carrying to much up top as its got small deto signs on the plug so i will back it off
    easy just 30secs on the computer
    You got to love programable igntion systems
  • 10-01-2008 05:24 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    im still working hard on getting it right
    the cvt is the hard thing to get right
    I have it reving at 11000 and then overeving to about 11500 when the variator locks up
    Im going to pull more timing out at 11100 to see if i can heat the pipe more and get more over rev and add to its top speed
    I think its slipping the belt now as the power hit and it goes but about 1/2 sec later it takes of faster , this is with out the engine rpm changing so i figure its not the clutch as it would rise in rpm
    Im wondering if i need to go to a red contra spring
     Jason
    what do you think
    Also a pic of my tuning aid
    it gives me engine temp egt and rpm as well as data logging
  • 10-02-2008 05:58 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well i got sick of the belt slip , i went and got a red contra spring then did what every body would
    I pulled it down and gave the cases a bit of a tickle
    this way i can install my fully circle crank as well and maybe the inner rotor
    i spent a bit more time shaping into the boost ports this time
    the last cases i did i dont think flowed as much into the boost as they could have
    i have it sitting there now with the jb weld going off and a quick sand blast tomorrow then back together
  • 10-03-2008 11:47 AM In reply to
    • waxhead
    • gold coast
    • Posts 882
    here is the final result
  • 10-03-2008 03:17 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    just setting up the inner rotor ignition
    still debating in my head if to put an electic pump in or not
  • 10-03-2008 05:49 PM In reply to
    Can't wait to see your creation out & about  Devil
    Looking sweeeet!
    Geeked
  • 10-03-2008 05:55 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    yeah it would have been going today but i cant find a bolt damn it
    still have to get the right clutch springs as well as the right weights in it
    here is the ignition curve i am running in it
  • 10-06-2008 02:34 PM In reply to
    Big Smile  I was gonna say something technically smarty pants, like, "Oh, is the anomoly in the latter 3/4 related both carbuation & powerband notwithstanding the final stages henceforth the ulterior objective?"  (EH???)
    Yeah......I've never been any good with BS which is why I don't bother!  LOL  Big Smile
     So what do all those lines mean???  Please tell us Mr. Wax.  I can bet the summary is optimal spanky kickarse power.
    Rob  Geeked
  • 10-06-2008 04:51 PM In reply to
    waxhead:
    Hell no
    his thing his nuts
    Oh don't be modest!!!
    Rocket Rob:
    LMBFHAO!!!  Rob, that sounded entirely plausible to me.....LoL!!!  Mind you when you deal in it, it all starts to sound the same ( or smell the same)
    Question for the Wax, Who or where are you sourcing your perf parts from or is it a industry secret? I've got a number of leads now but more is good for when I'm ready to finish rebuilding the 2 Jive engines.  They won't be anything fancy but I'm hoping to have the standard shape Jive similar in get up and go to Robs Bandits. Should be fun for the track. but by the sounds of things, I'll probably be a fair way down compared to rob but i don't mind as it will be good to learn and see what I'l need to do to get up there.
    so if I may say " Show me the ladder, I'll climb it myself"  and if things go the way they are sounding, next time we get to race we might just have our own grid!!!
  • 10-06-2008 05:23 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    ok well all my parts to date have come from scooter centre
    except the ignition as i am the agent for them in australia
    however i am just about to launch my own fully programable system of my own
     I do all my own porting and engine work
    On another Note i just started it up and gave it a rev
    It sounds nuts. I cant wait to get out there and ruin some other people day at the traffic lights
    Just have to dial in the carb and the variator now
    But i am over it for today
