New aerox build up
Last post 05-01-2010 10:09 PM by bpt4w. 96 replies.
Page 4 of 7 (97 items) « First ... < Previous 2 3 4 5 6 Next > ... Last »
  • 02-18-2009 05:26 PM In reply to
    • waxhead
    • Joined on 12-17-2007
    • gold coast
    • Posts 882
    Re: New aerox build up
    mhr 50cc cylinder
    might as well start with the most powerfull 50cc cylinder there is out there
  • 03-02-2009 06:43 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    ok ordered my dr pulley hit clutch
    it was smoking the old one off the line and it was killing the power
    Not cheap but they are the best you can buy so i guess you only have to buy it once
    The mhr delta clutch was a joke( like a lot of malossi stuff) and it going in the bin as soon as the decent stuff turns up
  • 03-02-2009 08:41 PM In reply to
    Isn't the Malossi adjustable?  Can't weights be added to make it bite harder?
  • 03-02-2009 09:01 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    yes they can be
    it has the heavy weights in it
    but the whole body of the clutch has distorted
    It buckled under the load of a 70cc
    not really what i had in mind when i brought it about 6mths ago
  • 03-03-2009 08:15 AM In reply to
     Struth!  I thought Maslossi made race stuff to be punished.  That delta clutch is the one with the bracing plate, no?  Stage 6 is a similar design, if I remember rightly.
    I've got PMTuning adjustables in mine.  Bang for Buck, ok (when the AU$ was more favourable) , but I'd like them to bite harder, & I'm already on the softest spring setting.....all I can think to do is get some heavier screws in there that appear to do nothing but add weight to the shoe. I've bedded them in, too, but still too lame.
    I've got Malossi bells in there.....they seemed quite cheap, & I was going for strength.  I had my sights on those Asian ones (can't remember the make) with loads of vent holes in the bell surface.
    Rob   Geeked
  • 03-03-2009 08:45 AM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Yeah i am running the braced clutch
    But the plates are no longer hitting the bell correctly
    its a polini bell
    i have looked at the bell and its fine other than the fact its now overheatd due to the mallossi clutch not hiting square and so slipping
  • 03-05-2009 08:45 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    I figured if big breaks are good
    then i should go for big breaks
    Introducing my 240mm rotor
  • 03-07-2009 06:18 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well i have a yazuni c21 to try next
    Will be interesting to see what i can get htis thing to do
    Less weight more hp
    got to be a good combo
  • 03-11-2009 04:33 PM In reply to
    waxhead:
    It'll be interesting to see how it translates to your take-off.  I notice the Dr Pulley bell is a finned jobby.
    They certainly sound interesting, & I found a few vids about them from mrp.com
    http://www.youtube.com/v/8cSt5xaMreU <p><a href="http://www.youtube.com/v/8cSt5xaMreU">http://www.youtube.com/v/8cSt5xaMreU</a></p>
    http://www.youtube.com/v/BlB6bVNnsDM <p><a href="http://www.youtube.com/v/BlB6bVNnsDM">http://www.youtube.com/v/BlB6bVNnsDM</a></p>
    While I'd like more bite from my clutches, if there's too much then my PMTuning ones might mangle themselves up.
    Apart from more revs with a slightly tighter setting so that Shel & I can rev the bikes to try making as much noise as Jason Devil  Our clutches should behave the same as last time out at Lakeside, so next time out it should be interesting to see how yours compares.
    Rob  Geeked
  • 03-11-2009 10:54 PM In reply to
    Hi Waxhead let us know how the new clutch goes, my delta is doing the same, got a 2fast by trt 80 kit, stroker crank, inner rotor ign, trt pipe, 28mm flat slide carby, about 2 go in and need a good clutch 2 hold it, did'nt know what 2 get this might help me 2 decide.
  • 03-12-2009 03:09 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    wow thats a hell of an engine you are building there
    would love to see a pic
    will let every one know how it goes when it turns up
  • 03-12-2009 08:20 PM In reply to
    i would if i knew how, im planing 2 bring it 2 a lakeside track day 4 a run once its done and running, still be a while yet i go away in 2 weeks 4 work 4 10 weeks so it will be after that some time.
  • 04-27-2009 03:56 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    I have been dialing in my dr pulley hit clutch
    Man these things are awesome , cant say enough good stuff
    I took it in for a road worthy as I want to ride on the road as well, the mechanic freaked out when he gassed it and the front wheel popped into the air, it was priceless to see his face
    It had the front wheel about 2 feet in the air
  • 09-16-2009 09:41 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Ok well Scooter is going very strong
    But i have decided with the racing that im going to make a dedicated race bike out of it
    I have been speaking with a shop and talking to them about sponsorship so if all goes well there will be painted aerox racing around the track
    With a bit more gear on it as well as alot more gear off it
  • 09-18-2009 06:45 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well i ordered the new intake manifold today ,im going to rear mount the carb to get a better aproach angle on the engine
    I have also ordered a larger carb to allow for more air into the engine as i think the 21mm has reached its max potential on this engine
