Check Your Tyre Pressure!
Last post 10-09-2008 03:18 PM by Drebin. 20 replies.
Page 1 of 2 (21 items) 1 2 Next >
  • 10-01-2008 08:15 PM
    It looks like I rode over 250km on Monday on a flat front tyre! I had topped up the air at the service station but had some trouble with the faulty hose obviously meaning that air had leaked out. The funny thing is that of the boys I asked about my experiences - feeling sluggish on the bends, vibrating handlebars & odd noise, none thought it could be due to a flat tyre! To think of the distances & speeds we rode at! On a tyre that today was holding under 20PSI when it should have been 36PSI. OUCH!
    I am woman! Hear my scooter roar! LOL
    As Tekema2 said to me on messenger - Atleast the LG is still reliable on a flat tyre.
  • 10-01-2008 08:29 PM In reply to
    • Posts 7,090
    Re: Check Your Tyre Pressure!
    You'll only ever do that once!
    ps I've done the same thing
  • 10-01-2008 08:37 PM In reply to
    you gotta watch out for that! I ride on 17psi front, 25psi rear... :)
    Vespa PX200 "Killer Wasp" - now on a street near you
  • 10-01-2008 08:50 PM In reply to
    • scootergeek
    • Joined on 06-22-2008
    • Perth (SOR), Western Australia
    • Posts 70
    Had that experience, stopped at a petrol station, air pump wasn't helping; their compressor hadn't been turned on that morning !!
    Thanks to someone in the riding group  for quizzing the attendant.
    Kymco Agility 125cc
  • 10-01-2008 09:15 PM In reply to
    ScootaChic:
    LG front tyre should only be 25psi - rear 32psi.    If you are carrying a passenger - 32 for front, 36 for rear.
    Over-inflated tyres can be dicy too because there is less surface contact point.  Carry your own tyre gauge. The one on the servo pump is almost guaranteed to be inaccuarate.
  • 10-01-2008 09:23 PM In reply to
    That's a bit embarrasing but I bet you have learnt something from it
  • 10-01-2008 09:59 PM In reply to
    muzzie:
    Really? Info on the tyre states 36/40 (MAXXI Tubeless)
  • 10-01-2008 10:00 PM In reply to
    Dakoda:
    Sure did! Trust my own instincts regardless of what the boys say! Wink
  • 10-01-2008 10:21 PM In reply to
    There's a tyre placard just below the coolant window with the recomended pressures, also in the manual.  I think the numbers on the tyre are just for the max permissible psi, not neccesarily the recommended.
  • 10-01-2008 10:52 PM In reply to
    muzzie:
    correct Muzzie.
  • 10-02-2008 06:48 AM In reply to
    So do you go by what your tyre says or what the book says.
    And what if you dont have the standard tyres on the bike which it came with?
  • 10-02-2008 09:06 AM In reply to
     i had a faulty tyre pump that wouldn't pump any air into the tyre but it was leaking air everytime i tried to pump up the tyre so i rode around the corner on tyre with low pressure . my god it was terrible. woldn't turn, the tread was moving underneath you as you rode.
  • 10-02-2008 09:48 AM In reply to
    Dakoda:
    Go by the book Dak. If your aftermarket tyres are the same spec as original, then stick with the book. If they are different spec to original, check with the guys that fitted them -I'm guessing Brendo at ScootieHQ, they'll clear it up for you. But the book is a good indicator...
  • 10-02-2008 10:10 AM In reply to
    Dakoda:
    Definately book. Scoots often have different pressures due to design factors like weight distribution. A rear heavy scoot will often run a softer front pressure than "usual" for extra grip (like 26psi) & higher rear (like 34psi). Tyre pressure guide on the tyre is a guide for the tyre, the book is what the factory has teseted & found best for that specific scoot.
    What tyre pressure you run is also a way of fine tuning the scoot to your personal needs. I adjust mine all  the time to suit what I'm doing. If I want to go for a twisty mountain blast of the GP1 I'll loose 2 Psi in each tyre for grip, for commuting just standard settings & highway work I'll add 1-2 Psi for less rolling resistance & longer wear.
    Have a play with the pressures, you will be surprised by the different feel you get with a couple of psi here or there. Remember never trust the service station gauge (get your own, every scooter rider should have one) & check the pressures with a cold tyre if possible.
  • 10-02-2008 10:38 AM In reply to
    • Blam
    • Joined on 08-25-2008
    • Posts 437
     It's very important you get the tyre pressure right and you check it every month at least.
    Under or over inflating the tyre will cause bad handling, greater fuel consumption and much more tyre wear.
