Vmoto Milan parts
Last post 12-29-2008 07:44 PM by Ned. 6 replies.
Page 1 of 1 (7 items)
  • 12-25-2008 09:50 AM
    • Ned
    • Joined on 12-21-2008
    • Posts 137
    Vmoto Milan parts
     As an old boy scout lol I like to be prepared, and also to do the odd self service. I've got drive belt sizes etc for the monza from posts here, but it seems to me that the Milan engine has more in common with the Yamaha Jog.
    wwww.gpsimports.com.au has stacks of parts for Jogs. I am looking at buying a drive belt and head gasket for a self service, amI right that Jog parts should fit ok?
    VMoto Milan JX 50 blue(ish)
    "It's all over now, baby blue"
    Honda NH80 rat-bike
    "aqua-rat" until I take the spraycan to it...
  • 12-28-2008 05:31 PM In reply to
    • waxhead
    • Joined on 12-17-2007
    • gold coast
    • Posts 882
    Re: Vmoto Milan parts
    yes you will find alot of parts fit
    I think you will find the engine has more in common with the cpi scooter
    large taper crank with the shorte stroke
  • 12-28-2008 07:08 PM In reply to
     its funny though, I thought that they were a copy of a yamaha until somebody pointed it out.
    By the way, if anyone can answer this: what is a gy6 engine? is it just a common
    engine used by alot of chinese manufactorers?
  • 12-29-2008 08:03 AM In reply to
     Maybe shoot Brendo at Scooter HQ a PM just to check your model as I think from previous posts he has differentiated two models of the Milan. i.e two separate year ranges
    The GY6 engine is used across numerous scooters, you are right in thinking that this is a very commonly used motor .
  • 12-29-2008 09:26 AM In reply to
    • E2W
    • Joined on 04-21-2008
    • Fitzroy North Melbourne
    • Posts 482
    You have to be carefull when trying to fit parts from other brands of scooter. Although they look the same I've found some engine internals change between brands such as piston pins, pistons, transmission pullies, belts and rollers that end up being the wrong parts when you try to install them.
    Everything Two Wheels
    www.everythingtwowheels.com.au
  • 12-29-2008 11:52 AM In reply to
    • waxhead
    • gold coast
    • Posts 882
    There is a few differences in the cranks and the pistons
    you have a 13 and a 16mm crank with different tapers as well
    You also have a 12mm and a 10mm gudgeon pin
    I would think yiu will have the 16mm crank with the large taper and the 12mm gudgeon pin
  • 12-29-2008 07:44 PM In reply to
    • Ned
    • Posts 137
     OK, thanks guys, it's a 2004 milan...I think from what I have read I have the 12mm gudgeon in that year, that means it will be closer to the Jog than the previous model, yeah?
    Honda NH80 rat-bike
