Back wheel removal- Cygnus
Last post 04-28-2009 08:09 AM by ciggie. 5 replies.
Page 1 of 1 (6 items)
  • 04-25-2009 11:20 PM
    • ciggie
    • Joined on 04-25-2009
    • Posts 3
    Hi All,
    I am new to this forum and to scooters Smile
    I havea 2006 cygnus 125 and I am wondering how on earth you remove the back wheel. I tried to undo the 24mm nut on the other side of the photo and it wouldn't budge. Do I have to remove that drum and variator thing?
    How do I remove the wheel?
    There is an extra degree of diffuclty as the scoot on up on 2 milk crates....
    Thanks
    Project Ciggie- Smashed front end
  • 04-26-2009 01:04 AM In reply to
    Re: Back wheel removal- Cygnus
     My Zuma which was similar took a 24mm socket with a half inch L bar and a 1000mm pipe to undo the nut.
    We ended up backing the scooter into a stair, sitting a big guy on the scooter with the brake on and another big guy on the pipe and it took a lot of force.
    Mechanics do them up with rattle guns and over tighten them and every other bolt they seem to touch.
    I have a rattle gun but don't use it for tightening other than the crankshaft and clutch nuts.
  • 04-27-2009 08:20 AM In reply to
    • ciggie
    • Posts 3
    Do I need to remove anything from the transmission side?
    Is it simply a case of somehow removing the 24mm nut and the wheel will come out?
    thanks
  • 04-27-2009 10:02 PM In reply to
     On the Zuma and Bee Wee I took the exhaust off and then undid the 24mm nut.  It took some tapping with a rubber hammer on the shaft to free the wheel.
  • 04-28-2009 12:26 AM In reply to
    Hi ciggie,
                 I have the exact same scoot, if you take further pics of your progress I would be interested to see. I guess changng a tyre on the side of the road is not on with this one eh Hmm.
    I'd guess there should be a torque setting when you do it back up rather than just tightening till your eyes bulge. Smile
    Good luck
    Do more with less Cygnus125 then 250Virago
    Get outa town the wheels wont stop
    alias Hardly Viragoson
  • 04-28-2009 08:09 AM In reply to
    • ciggie
    • Posts 3
    thanks, I will let you knou how I go.....
