aerox 100 wheel mod
Last post 12-21-2010 09:35 PM by jnr_747. 4 replies.
  • 12-16-2010 10:59 AM
    aerox 100 wheel mod
     Hey guys recenly got a yw100 with 11 000ks its kicking ass gives my old ss outlaw a run for its money glad got away from chinese scoots *pukes*... HOWEVER! I've seen cracka with his mod of aerox wheels, but how do I fit them on my scoot?? Both models have same brakes but will the aerox wheels fit on the yw100 with ease or do I have to change forks and rear shock? Also the wheel base on the yw 100 is 1210 and the yq100 is 1290 but got heaps of room on the yw100? with the wheels fitted would I have to make a spacer aswell? any feed back please?
    life starts at 100cc
  • 12-16-2010 02:43 PM In reply to
    Re: aerox 100 wheel mod
     yes things are a little different, the back wheel bolts straight up.
    the front however is a bit different i scratched my head for a while before replacing the forks with areox jobbies
    aswell.
    You will need a aerox front disk as the beewee one is different and unless you run the aerox caliper you will need to finesse
    the beewee caliper to fit, just a little file ing here and there.
    i hope this helps, just remember nothing is ever as easy as it sounds and rarely will anything fit without modding.
    130cc stroker, V8 pipe, keihin28mm, ncy inner rotor, malossi variator, stage6 mkII clutch and bell
  • 12-20-2010 01:15 PM In reply to
     are spacers needed for the rims aswell?
  • 12-21-2010 06:46 PM In reply to
     you will have to work out spacers yes unless you run all the aerox bits including spacer and forks bearings etc.
  • 12-21-2010 09:35 PM In reply to
     aww nice ones! Big Smile
