Repainting The Vespa
Last post 10-08-2011 08:21 PM by eviladrian. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • 05-28-2011 02:43 PM
    I'm about to have a go at fixing up a scar on the Vespa's side that was the result of a gentle lay down a year ago. The Ace mechanic (he is too!) tried the touchup paint that came from Piaggio but it was too dark & I think made the area look worse.
    So... any tips, suggestions or advice would be wonderful.
    I have -
    • Sandpaper for the initial sand back (how far back do I go?)
    • a spray can of primer (how many coats? how long do I leave it before applying another coat?)
    • sandpaper to smooth out the primer
    • a spray can of paint that was matched both by eye & a handheld scanner thingy the guy at the shop used (how many coats? how long do I leave it before applying another coat?)
    • a final sandpaper to smooth out the paint
    The guy also mentioned another product that would shine up the paint if needed, but did suggest I wouldn't need it.
  • 05-28-2011 04:33 PM In reply to
    Re: Repainting The Vespa
    I don't think I'll give up my day job just yet to take up vehicle painting. I'm gonna sand it back again with the medium grade sandpaper & see if I can get those paint runs out. Also got to head back to the paint shop & pick up whatever the product was that would gloss it up a bit.
    I'm not convinced I've made the panel look better than it was prior to my attempt at painting it. Smile
  • 05-28-2011 04:52 PM In reply to
    sand it gently with 1200 wet n dry until it flattens, then recoat and repeat, finally finish with 2-3 coats of clear acrylic with a light sand between each coat. Wait a week then buff and polish.
    Slow Down & Enjoy The Ride
    2012 Kawasaki W800
    Go the Retro
    Looking for another BeeWee :)
  • 05-30-2011 04:38 AM In reply to
     Start by practicing on a piece of old panel or metal sheet before having a go on the Vespa  .Some googling should answer all the rubbing down preparation & spraying questions
  • 06-01-2011 12:04 PM In reply to
    • hank
    • Joined on 12-01-2010
    • Posts 281
     can of satin black
    then 12months later get a pro to do itWink
  • 06-04-2011 01:42 PM In reply to
    hank:
    hehe
    Ok, lessons learnt from this little exercise. If it looks anywhere NEAR ok at the first attempt be happy with it as it is or else a minor touchup job WILL turn into a major exercise. If you can't then give up & take it to a pro. I've given the m/c panel beater fair warning & will be taking the Vespa around for a quote to clean up the mess I've made of it as well as tidying up the floorwell as unfortunately the floormats don't protect the paint as I thought they would.
    It was a worthy exercise & certainly worth having a go at. Although I may think diferently when I see the quote for the repaint! Big Smile
  • 06-05-2011 04:38 PM In reply to
    I had a low-side spill a couple of weeks ago, in which I also hit my shoulder hard enough for the doctor to ban me from riding for about 3 months, so I've decided to spend my down-time repairing the scratches.
    I had a go with some cheap spraypaint and an old headlight cover I had lying around, but the results were less than spectacular:
    Apparently this kind of cratered look is caused when you don't clean and dry the surface properly before spraying, so it looks like I'll need some more practice before I start on the real job.
    First: Daelim S1 125
    Then: Honda PCX 150
    Now: Honda CTX 700
  • 06-05-2011 05:52 PM In reply to
     Yep the main thing is preparation if thats not perfect even the worlds best sprayers job will look crap Smile
  • 06-06-2011 04:28 PM In reply to
    The paint jobs on here could be improved GREATLY simply by using a product that I have found to help tremendously with the Orange Peel effect of the paint...
    Mr Buff's Cutting Compound...
    here is a link
    That stuff has worked miracles for me in fixing a really bad finish... if someone isn't happy with their painting effort I would give that a go before anything else...
    Piaggio 250 BV type R
    Aprilia Scarabeo 250ie
  • 06-06-2011 10:38 PM In reply to
    Will definitely have to give that a try. I have used Polyglaze cut & polish compound but would be ecstatic if the stuff you suggested gives a better result.
    Hell, if I'm happy enough with it the floorwell will be next on my hitlist as the floormat really doesn't protect the paint as I thought it would.
  • 06-07-2011 08:44 PM In reply to
    What have you done to me Bunnybasher!?! I've gone from deciding to get this done professionally to thinking "well, if I bought myself a proper sander/buffering equipment (saw one for $40 at Repco), sanded it RIGHT back & started again...
    All this from one pot of cutting compound! I couldn't find the one suggested so stuck with the turtlewax cut/polish that I bought the other day. Even that... It's nowhere near the gloss of the other panels but a vast improvement on where it was.
    Now... do I buy the equipment, restock on primer, paint & gloss in order to have another go or do I just take it to the pros? It's no longer an easy choice! Indifferent
  • 06-07-2011 10:23 PM In reply to
    what you up to this week?  I am home all week, want me to have a look at it and a do some cut and polishing, i got the buffer and stuff all handy... if you want to come by south perth let me know and i will have a go at it...
  • 06-07-2011 10:25 PM In reply to
    I have Friday off work. Could I possibly drop by in the morning for you to have a look at it please? I appreciate your offer of help. I would LOVE to be able to achieve a good look on this without having to take it to a pro, it would be so cool :)
  • 06-07-2011 10:35 PM In reply to
    can't promise results, but i can have a look and see what I can achieve!  pm or email me and i will give you my address - i think you have been by my place before to test out the Dr Pulleys and the pod filter before :)  anyways bring your sandpaper and your paint...
  • 06-07-2011 10:48 PM In reply to
    LOL ok, I think I'll need to grab more of both if that's the case :) I suspect that's part of the problem, I've emptied almost a whole can of paint onto 2 of the scooter's panels. Big Smile
    This means that if I do repaint the floorwell, I will do things VERY differently
