YamahaYp 250 Majesty starting Problems
Last post 01-14-2013 02:26 PM by hacka. 4 replies.
  • 01-13-2013 05:00 PM
    • hacka
    • Joined on 12-16-2012
    • Posts 3
    Hello to the Forum
    i'm a New Member and wondering if anybody out there can help me with a Problem ,
    i own a Yamaha yp 250 Majesty and have a Problem with my Starting Clutch (Starter Motor just spins freely without engaging)
    has anybody experienced this and if yes what is involved to fix it ,
    any help would be greatly appreciated
    Regards
    hacka
  • 01-13-2013 06:59 PM In reply to
    Re: YamahaYp 250 Majesty starting Problems
     Welcome hacka sounds like the solenoid that engages the shaft against the flywheel isn't working . Probably will have to remove starter motor from scooter to try and see what the problem is
  • 01-14-2013 12:13 PM In reply to
    • Greg
    • Joined on 06-08-2008
    • Tuart Hill, Perth, W.A.
    • Posts 133
    It's probably an inertia starter motor (no solenoid) if you can see the starter it will have a cylindrical body, if it has a solenoid it will have another smaller (solenoid) unit on the side of the main body.
    http://a1biofuel.net/Diesel-Tips.html
    scroll down and you'll see the two types
    Greg
    Yamaha Tmax 500, 2010 Black ... Sold her for ...
    Suzuki V-Strom 650 2012
    Perth W.A.
  • 01-14-2013 02:23 PM In reply to
    • hacka
    • Posts 3
    Thanks pyrah
    i think i found the problem in the Starter Clutch not engaging
    looks like i might have to pull it out and inspect for wear
    cheers
    hacka
  • 01-14-2013 02:26 PM In reply to
    • hacka
    • Posts 3
    Thanks for your reply Greg
    i think i might have found the problem in the Starter Clutch not engaging ,
    i need to pull it apart and check for wear
    cheers
    hacka
