Protective products?
Last post 10-30-2013 12:06 AM by pyrah. 16 replies.
Page 1 of 2 (17 items) 1 2 Next >
  • 09-19-2013 12:33 PM
    • Kingo
    • Joined on 09-19-2013
    • Posts 11
    Hey guys, first time scooter owner here. Just purchased a brand new little tgb 101s (loving it, filled the tank and love it more) Just had a few queries..
    First is oils.. Any recommendations on a quality oil at a reasonable price that i can buy for cheaper by 5, 10 or 20 litre bottles?
    Secondly, i am stoked i can keep my scooter in the garage with my wife's car at home, but is there any known brands or products to clean and protect the plastic from the harsh qld sun?
    I had forgotten all about the running in period, first 1000 k's is gonna be brutal without opening it right up for extended periods. Any advice on de restricting? When to do this, pros and cons..
  • 09-22-2013 08:50 PM In reply to
    • Kingo
    • Posts 11
    Re: Protective products?
  • 09-22-2013 09:03 PM In reply to
    • gaz
    • Joined on 11-04-2009
    • Posts 322
    Hey Kingo I don't know much about these scoots but I just 'googled' your scooter & there's a lot of info including 'oils change' that could help you.
  • 09-23-2013 06:00 AM In reply to
    • Kingo
    • Posts 11
    Ha awesome gaz, as i said i am a new scooter owner, and had been doing the same with google. I have only found a handful of recommendations on waxes for the plastics from another forum. Do you ride a 2 stroke? Which oiled do you use?
  • 09-23-2013 06:12 AM In reply to
  • 09-23-2013 02:02 PM In reply to
    • gaz
    • Posts 322
    Nope,I ride a 4 stroke 150cc.
    Kingo:
  • 09-24-2013 09:00 PM In reply to
    Generally, most scooters don't NEED the motorcycle specific JASO MA/MB standard oil - the clutch doesn't get anywhere near the oil (as I understand it).
    Good quality Car oil of the right weight (something W something, check your owner's manual) and the right grade or higher (SG is probably not good enough, the further down the alphabet the better).
  • 09-24-2013 09:54 PM In reply to
    wombat:
     Believe the TGB 101s is a 50cc two stroke so above post not applicable to original question .  Good post on oils for four strokes here though if I'm wrong click Big Smile
  • 09-25-2013 05:43 AM In reply to
    • Kingo
    • Posts 11
    Thanks for the info guys. Now just need to find. Mechanic who does mods in brissy.. Anyone k or if its bad to change Cdi while running in?
  • 09-25-2013 07:57 PM In reply to
    • gaz
    • Posts 322
    To get 'mods' done in brissy :  www.precisionscooters.com.au
  • 09-25-2013 08:17 PM In reply to
    • Kingo
    • Posts 11
    gaz, thanks for the info mate- but already tried this guy and he has closed shop. The dealer i bought from is not keen to do the work either, however i have found a guy 'freedom on two wheels' who has stated he will do the work if i can supply parts.
    So now wondering on what mods exactly i should be doing? Crazy busy at work so would be good to get it all done in one go. Not interested in a 70 cc kit and from what I can find on other forums etc is
    unrestricted cdi
    sports exhaust
    new rollers/sliders for variator ?
    Changing these should get me another 10k/hr top end? Anyone have experience with these 'mods' on a 50?
  • 10-26-2013 06:54 AM In reply to
    • Kingo
    • Posts 11
    So i have taken the scoot in for its first 500 k service. Mechanic tells me they already take out the spacer in the transmission and the cdi is not restricted. Seems there is no upgrades i can do to get that 65 -70 k top speed i was after, without engine work like a big bore kit etc.. Anyone that can confirm this?
  • 10-26-2013 09:15 AM In reply to
     Would probably try a performance exhaust and rejeting of carburettor in the first instance
  • 10-26-2013 09:34 AM In reply to
    • Kingo
    • Posts 11
    Great mate,
    i just need to find a local Brisbane mechanic that can supply and fit.. Any recommendations?
  • 10-26-2013 12:24 PM In reply to
     Know of Show & Go in Adelaide that do parts as for a Brisbane mechanic to do the work hope someone from there can post a recommendation
    http://showandgo.com.au/
