If it has antidive valves for the front suspension, then the valve and piping might be blocking the return fluid flow.
Old brake lines can fail with the internal hose swelling and blocking under pressure. The brake dragging could have a dud line.
There is little value using DOT 4 fluid, after a few months its deteriorated to no better than DOT 3. DOT 4 is really most usefull on racing systems.
Are the hydraulic lines seperate off the master cylinder or do they have a single line into two
