New aerox build up
Last post 05-01-2010 10:09 PM by bpt4w. 96 replies.
Page 1 of 7 (97 items) 1 2 3 4 5 Next > ... Last »
  • 07-31-2008 07:06 PM
    • waxhead
    • Joined on 12-17-2007
    • gold coast
    • Posts 882
    New aerox build up
    Well i brought an aerox and decided its time to do that up
    i was having issues witht eh scp trying to find a place to fit the radiator
    easiest way around it buy something with a radiator
    they dont get much better than the yamaha aerox
    I am picking up a spare engine this weekend thanks to a member on here , thanks very much
     I already have a good cylinder (mhr rep) and i will be running a stroker crank in it
    hoping to get to about 80cc out of it
    maybe slightly more  we will see
    I am planing on running a c21 or a c16
    Will post pics as they come avaliable
  • 07-31-2008 07:54 PM In reply to
    Re: New aerox build up
    Cool stuff, Wax.
     I look forward to seeing your creation out on the track.
    I enjoy your detailed tuning pics.
  • 07-31-2008 08:12 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Thanks rpm Also thanks to Jason who is helping me out with an engine to allow me to build this one correctly aand have no down time on the scooter
     I will be pulling all the good stuff out of the scp runner engine including the ignition , crank maybe etc
    I will port up a new set of cases so if some one wants to buy a set of cases for the scp that have been already ported etc
    then let me know
  • 08-18-2008 06:59 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well the Aerox turned uptoday
    its the buildup time coming , wow stock is so boring
    Bad luck on the cases it turns out they werent the right ones but thanks so much for trying jason
    I have the 70cc kit and the inner rotor
    i will be getting the c16 soon and porting the cases etc
    Pictures coming as the engine progresses
  • 08-18-2008 08:32 PM In reply to
    Hey there. I just bought a new 2006 Aerox. What year is yours? I will ride stock for a little while before I make tuning (sic)... Stick out tongue
    Haven't even picked mine up yet. I assume it will have a variator restriction? And is the stock CDI rpm limited? Was a hassle getting a CDI for my Jog from Nippon.
  • 08-18-2008 08:48 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Hey there
    My scooter is an 06 as well
    yes i believe the aerox has a limiter in the cdi
    but i am getting rid of the total ignition so its not an issue
  • 08-18-2008 09:01 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    I have a ginaelli pipe as well as a lazer pro
    all good pipes but not capable of going above 15hp which is where i am trying to go with this engine
    If i could find some one that could roll tapers for me i would make my own
    but making tapers is to hard for me  if i want them right
  • 08-18-2008 09:55 PM In reply to
    Hey Wax, I, like Rob, look forward to your interesting post and pics.
    My twin jives project has stalled a little due to low work/funds stuffups but turning that around now. Anyway, both jives came with Gianellis and they're pressed. Would it be possible to press 2 halves of a tapered section maybe then tigweld it together???
    But dunno how much pressure you'd need to do it to the right thickness of material.....  Maybe I'm just piddlin' in the breeze there.
  • 08-18-2008 10:12 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Thanks man
    I had thought about using a press to try and make halves as well
    I can make one half on the lathe at work
    Its just the female one i cant make so easily its to hard to spin in the lathe, but you have given me an idea on how to make the exhaust
    Kinda easier to buy one i think but i will have a think about it
  • 08-19-2008 10:04 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Well i will be ordering my city 16 this week
    I decided to go with that and not try and make one
    Also got a wing bell  and a delta clutch on the way at the same time
    I will be using the bgm crank out of the scooter engine i have already
    I considered an overrange but didnt want to lose my electric starter
  • 08-25-2008 07:06 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    I got sick of the slow scooter so i put the pipe on it to get me over the boring wait until all my parts arrive
    its going alot better but nothing like its going to go , cant wait
  • 08-29-2008 09:59 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    well just finshed cleaning up the cylinder and porting it slightly
    its came in at 196 ex and 130 transfers
    Just where i want it
    this thing should pull good revs and make good power
  • 09-02-2008 07:34 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    Clutch turned up and so did yasuni city 16( already derestricted it )
    I will be pulling the engine down in about 2 weeks and making this bad boy go
  • 09-02-2008 09:50 PM In reply to
    Hiya waxhead.
    I derestricted mine on the weekend and fitted a Multivar, 6g weights and a white spring as well as a derestricted Gianelli Next. Goes nice. They are a quality scoot.
    Have yet to touch the engine but have some bits on order. A Hebo Manston Rep kit, Delta Clutch, reeds and manifold.
    Will need a bigger carb than stock, probably 17.5 or 19mm but was hoping to keep existing cables, choke and airbox setup.
    Do you know what carb I need to drop straight in? Dellorto PHBN?
    Cheers,
    FoF
  • 09-02-2008 10:00 PM In reply to
    • waxhead
    • gold coast
    • Posts 882
    i am going to be putting on a 21mm on mine
    i would suggest you go for the same
    i cant say with cabling but i know the 21 will fit the stock intake
    However i just brought a derestricted one for mine to make it easier
    The 21 will use more fuel but does it really matter its not like these thinsg are hard on gas is it
